Ana içeriğe geç
Motorola Droid Camera Assembly Replacement
Neye ihtiyacın var
  1. Motorola Droid Camera Assembly Replacement, Battery: adım 1, 3 resimden 1. Motorola Droid Camera Assembly Replacement, Battery: adım 1, 3 resimden 2. Motorola Droid Camera Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
  2. Motorola Droid Camera Assembly Replacement: adım 2, 1 resimden 1.
    • Grasp the upper left corner of the battery and lift it out of its housing.
  3. Motorola Droid Camera Assembly Replacement, Rear Case: adım 3, 1 resimden 1.
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
  4. Motorola Droid Camera Assembly Replacement: adım 4, 2 resimden 1. Motorola Droid Camera Assembly Replacement: adım 4, 2 resimden 2.
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
  5. Motorola Droid Camera Assembly Replacement: adım 5, 2 resimden 1. Motorola Droid Camera Assembly Replacement: adım 5, 2 resimden 2.
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
  6. Motorola Droid Camera Assembly Replacement: adım 6, 1 resimden 1.
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  7. Motorola Droid Camera Assembly Replacement: adım 7, 1 resimden 1.
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  8. Motorola Droid Camera Assembly Replacement: adım 8, 1 resimden 1.
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  9. Motorola Droid Camera Assembly Replacement: adım 9, 1 resimden 1.
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  10. Motorola Droid Camera Assembly Replacement: adım 10, 2 resimden 1. Motorola Droid Camera Assembly Replacement: adım 10, 2 resimden 2.
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  11. Motorola Droid Camera Assembly Replacement: adım 11, 2 resimden 1. Motorola Droid Camera Assembly Replacement: adım 11, 2 resimden 2.
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
  12. Motorola Droid Camera Assembly Replacement, Speaker: adım 12, 1 resimden 1.
    • Carefully lift and remove the speaker assembly up out of the phone.
  13. Motorola Droid Camera Assembly Replacement, Motherboard: adım 13, 3 resimden 1. Motorola Droid Camera Assembly Replacement, Motherboard: adım 13, 3 resimden 2. Motorola Droid Camera Assembly Replacement, Motherboard: adım 13, 3 resimden 3.
    • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
    • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
  14. Motorola Droid Camera Assembly Replacement: adım 14, 1 resimden 1.
    • Peel the black tape covering the side button and display ribbon connectors on the motherboard.
  15. Motorola Droid Camera Assembly Replacement: adım 15, 1 resimden 1.
    • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
  16. Motorola Droid Camera Assembly Replacement: adım 16, 1 resimden 1.
    • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
  17. Motorola Droid Camera Assembly Replacement: adım 17, 1 resimden 1.
    • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
    • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
  18. Motorola Droid Camera Assembly Replacement: adım 18, 2 resimden 1. Motorola Droid Camera Assembly Replacement: adım 18, 2 resimden 2.
    • Carefully lift the motherboard from the front case and lay it next to the Droid, minding the keypad connector that is still attached.
    • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
    • Remove the motherboard from the phone.
  19. Motorola Droid Camera Assembly Replacement, Camera Assembly: adım 19, 2 resimden 1. Motorola Droid Camera Assembly Replacement, Camera Assembly: adım 19, 2 resimden 2.
    • Orient the motherboard so that the camera lens is face down.
    • Disconnect the camera connector from its socket by prying it straight up with a spudger.
    • Remove the camera assembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Newsom
42.164 İtibar
67 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 12,736
