Ana içeriğe geç
Giriş
A guide on how to replace the volume and power buttons on a Motorola Droid MAXX 2 smartphone.
Parçalar
Hiçbir parça belirtilmedi.
  1. Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Pull the sim card tray up out of the phone
    • Pull the sim card tray up out of the phone
  3. Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover. Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
  5. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Hemen Alışveriş Yapın
    iPhone X Fix Kits
  6. Pull the mid-frame off of the phone.
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  7. Remove the static tape covering the two connectors. Use a spudger to disconnect the battery cables from the motherboard. If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  8. Remove the disconnected battery from the phone.
    • Remove the disconnected battery from the phone.
  9. Peel back the orange adhesive covering the ZIF connector. Peel back the orange adhesive covering the ZIF connector.
    • Peel back the orange adhesive covering the ZIF connector.
  10. Lift the black tab on the ZIF connector up. Pull the ribbon cable out of the ZIF connector.
    • Lift the black tab on the ZIF connector up.
    • Pull the ribbon cable out of the ZIF connector.
  11. Use the plastic spudger to loosen the metal prongs that hold the button assembly onto the phone. Use the plastic spudger to loosen the metal prongs that hold the button assembly onto the phone. Use the plastic spudger to loosen the metal prongs that hold the button assembly onto the phone.
    • Use the plastic spudger to loosen the metal prongs that hold the button assembly onto the phone.
  12. Pull the button assembly up and out of the phone.
    • Pull the button assembly up and out of the phone.
Sonuç
Burke Seggerman
592 İtibar
5 adet Kılavuz yazıldı
Takım
Baylor, Team S3-G4, Williams Spring 2018 Baylor, Team S3-G4, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S3G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 15
Her zaman: 191
