Ana içeriğe geç
Motorola Droid MAXX 2 Rear Camera Replacement
Neye ihtiyacın var
  1. Motorola Droid MAXX 2 Rear Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Rear Camera Replacement: adım 2, 1 resimden 1.
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Rear Camera Replacement: adım 3, 2 resimden 1. Motorola Droid MAXX 2 Rear Camera Replacement: adım 3, 2 resimden 2.
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Rear Camera Replacement: adım 4, 1 resimden 1.
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Rear Camera Replacement: adım 5, 1 resimden 1.
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Rear Camera Replacement: adım 6, 3 resimden 1. Motorola Droid MAXX 2 Rear Camera Replacement: adım 6, 3 resimden 2. Motorola Droid MAXX 2 Rear Camera Replacement: adım 6, 3 resimden 3.
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Rear Camera Replacement: adım 7, 1 resimden 1.
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Rear Camera Replacement, Rear Camera: adım 8, 1 resimden 1.
    • Peel up orange adhesive that covers the ZIF connector.
  9. Motorola Droid MAXX 2 Rear Camera Replacement: adım 9, 1 resimden 1.
    • Use a spudger to lift up the black tab on the ZIF connector.
    • Remove the camera.
Sonuç
Burke Seggerman
704 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S3-G4, Williams Spring 2018 Baylor, Team S3-G4, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S3G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 299
