Ana içeriğe geç
Motorola Droid Mini Camera Replacement
Neye ihtiyacın var
  1. Motorola Droid Mini Camera Replacement, Back Case: adım 1, 2 resimden 1. Motorola Droid Mini Camera Replacement, Back Case: adım 1, 2 resimden 2.
    • Pull out the volume keys using the iFixit opening tool.
  2. Motorola Droid Mini Camera Replacement: adım 2, 2 resimden 1. Motorola Droid Mini Camera Replacement: adım 2, 2 resimden 2.
    • Pry off the back case gently using the iFixit opening tool.
    • Make sure to go around the entire perimeter of the case.
    I want to buy back casing of Motorola Altra mini
    Farah Azeem - Yanıt
  3. Motorola Droid Mini Camera Replacement, Camera: adım 3, 1 resimden 1.
    • Use a T5 Torx screwdriver to unscrew the nine silver screws from the housing frame.
  4. Motorola Droid Mini Camera Replacement: adım 4, 1 resimden 1.
    • Carefully separate the housing frame from the motherboard.
  5. Motorola Droid Mini Camera Replacement: adım 5, 2 resimden 1. Motorola Droid Mini Camera Replacement: adım 5, 2 resimden 2.
    • Carefully use the tweezers to separate the motherboard from the screen.
  6. Motorola Droid Mini Camera Replacement: adım 6, 2 resimden 1. Motorola Droid Mini Camera Replacement: adım 6, 2 resimden 2.
    • Carefully use the tweezers to remove the flash motherboard.
  7. Motorola Droid Mini Camera Replacement: adım 7, 2 resimden 1. Motorola Droid Mini Camera Replacement: adım 7, 2 resimden 2.
    • Use tweezers to remove the camera from the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alec Fales
337 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Leahy Fall 2014 USF Tampa, Team 9-2, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S9G2
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
What’s the OEM number of the flash motherboard ‘coz my flash died and I want to buy a new one.
Any help is much appreciated!
creativeinventiondesign - Yanıt
Hey where can I buy a new camera for my motorola?
Shayna W - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,641
