Parçalar
Hiçbir parça belirtilmedi.
Use the plastic opening tool to gently pry off the back case. Make sure to go around the entire perimeter of the case.
Use the T5 screw head to unscrew the 9 silver screws from the housing frame. Carefully separate the housing frame from the motherboard.
8 farklı kişi bu kılavuzu tamamladı.
4 Yorum
This guide is inaccurate in essentially every step.
A few examples:
1) there are 13 screws to remove the back housing
2) an additional 2 screws to remove the motherboard
3) fails to mention transferring power button and ear speaker
Just replaced a cracked screen on this model. This guide is pretty misleading. In addition to all the the things missing that the last commenter mentioned, it entirely fails to detail the most crucial part: replacing the screen. For which task you need a heat gun (hair dryer will do), metal spudger, replacement screen, and 1mm adhesive tape. I recommend this video to get a sense of what is actually involved: https://youtu.be/Q2tlwlHpZ04
I used the guide below to replace/re-attach the LCD and digitizer into the front frame. Sat the phone face down on a paper towel with books on it, while on a 3d printer bed heated to 80 degrees C, for total of about 20 minutes (IR thermometer measured screen/frame at around 65C). Will see how well this holds up…
