Ana içeriğe geç
Motorola Droid Pro Camera Replacement
Neye ihtiyacın var
  1. Motorola Droid Pro Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back cover using the thumb tab located on the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola Droid Pro Camera Replacement: adım 2, 2 resimden 1. Motorola Droid Pro Camera Replacement: adım 2, 2 resimden 2.
    • Remove the battery using the thumb tab.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola Droid Pro Camera Replacement, SD Card/SIM Card PCB Board: adım 3, 2 resimden 1. Motorola Droid Pro Camera Replacement, SD Card/SIM Card PCB Board: adım 3, 2 resimden 2.
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola Droid Pro Camera Replacement: adım 4, 3 resimden 1. Motorola Droid Pro Camera Replacement: adım 4, 3 resimden 2. Motorola Droid Pro Camera Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola Droid Pro Camera Replacement: adım 5, 2 resimden 1. Motorola Droid Pro Camera Replacement: adım 5, 2 resimden 2.
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola Droid Pro Camera Replacement, Motherboard: adım 6, 2 resimden 1. Motorola Droid Pro Camera Replacement, Motherboard: adım 6, 2 resimden 2.
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola Droid Pro Camera Replacement: adım 7, 2 resimden 1. Motorola Droid Pro Camera Replacement: adım 7, 2 resimden 2.
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola Droid Pro Camera Replacement: adım 8, 2 resimden 1. Motorola Droid Pro Camera Replacement: adım 8, 2 resimden 2.
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola Droid Pro Camera Replacement: adım 9, 1 resimden 1.
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
    FixBot'a Sor
    Yorum Ekle
  10. Motorola Droid Pro Camera Replacement: adım 10, 3 resimden 1. Motorola Droid Pro Camera Replacement: adım 10, 3 resimden 2. Motorola Droid Pro Camera Replacement: adım 10, 3 resimden 3.
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
    FixBot'a Sor
    Yorum Ekle
  11. Motorola Droid Pro Camera Replacement: adım 11, 2 resimden 1. Motorola Droid Pro Camera Replacement: adım 11, 2 resimden 2.
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
    FixBot'a Sor
    Yorum Ekle
  12. Motorola Droid Pro Camera Replacement, Camera: adım 12, 3 resimden 1. Motorola Droid Pro Camera Replacement, Camera: adım 12, 3 resimden 2. Motorola Droid Pro Camera Replacement, Camera: adım 12, 3 resimden 3.
    • The camera is located on the back side of PCB board.
    • Flip the board over and you will see that the camera is connected by a ribbon cable.
    • Unlock the cable by using a plastic remover tool then pull the camera out.
    • Insert the new camera and re lock the ribbon cable.
    • Do not use excessive force and make sure the cameras ribbon cable gets properly re seated.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Richard Bellizzi
352 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Miles Fall 2015 UMass Dartmouth, Team 1-6, Miles Fall 2015 üyesi
UMASSD-MILES-F15S1G6
3 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 412
