Ana içeriğe geç
Motorola Droid Pro SD Card/SIM Card PCB Board Replacement
Neye ihtiyacın var
  1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: adım 2, 2 resimden 1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: adım 2, 2 resimden 2.
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: adım 3, 2 resimden 1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: adım 3, 2 resimden 2.
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: adım 4, 3 resimden 1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: adım 4, 3 resimden 2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: adım 5, 2 resimden 1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: adım 5, 2 resimden 2.
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kyle Shays
836 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Miles Fall 2015 UMass Dartmouth, Team 1-6, Miles Fall 2015 üyesi
UMASSD-MILES-F15S1G6
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
lisa marie - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 313
