Giriş
Before continuing make sure you power down your device and work in a clean area. Also wear a static band to prevent damages to your device.
Neye ihtiyacın var
Remove the back cover using the thumb tab located on the bottom of the phone.
Using a T4 Torx driver, remove the eight 4 mm back panel screws.
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
