Ana içeriğe geç
Motorola Droid Pro Screen Replacement
Neye ihtiyacın var
  1. Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: adım 1, 2 resimden 1. Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: adım 1, 2 resimden 2.
    • Remove the back cover and battery by using the thumb tabs.
  2. Motorola Droid Pro Screen Replacement: adım 2, 1 resimden 1.
    • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
  3. Motorola Droid Pro Screen Replacement: adım 3, 1 resimden 1.
    • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use a little force to unlock them.
    • Go around on all sides then pull the back panel off.
  4. Motorola Droid Pro Screen Replacement: adım 4, 2 resimden 1. Motorola Droid Pro Screen Replacement: adım 4, 2 resimden 2.
    • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
    • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
    • Once the small one is removed the small board can be pulled off.
  5. Motorola Droid Pro Screen Replacement, Screen: adım 5, 1 resimden 1.
    • Unscrew the 6 screws using the T5 Torx screwdriver.
  6. Motorola Droid Pro Screen Replacement: adım 6, 1 resimden 1.
    • Unlock the ribbon cable and then you can pull the screen out.
    • When replacing screen make sure you lock the ribbon cable back in place.
Sonuç
Peter Cakounes
19 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S5G8
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 264
