Ana içeriğe geç
Motorola Droid Pro Screen Replacement
Neye ihtiyacın var
  1. Motorola Droid Pro Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro Screen Replacement: adım 2, 2 resimden 1. Motorola Droid Pro Screen Replacement: adım 2, 2 resimden 2.
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: adım 3, 2 resimden 1. Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: adım 3, 2 resimden 2.
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro Screen Replacement: adım 4, 3 resimden 1. Motorola Droid Pro Screen Replacement: adım 4, 3 resimden 2. Motorola Droid Pro Screen Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro Screen Replacement: adım 5, 2 resimden 1. Motorola Droid Pro Screen Replacement: adım 5, 2 resimden 2.
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
  6. Motorola Droid Pro Screen Replacement, Motherboard: adım 6, 2 resimden 1. Motorola Droid Pro Screen Replacement, Motherboard: adım 6, 2 resimden 2.
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
  7. Motorola Droid Pro Screen Replacement: adım 7, 2 resimden 1. Motorola Droid Pro Screen Replacement: adım 7, 2 resimden 2.
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
  8. Motorola Droid Pro Screen Replacement: adım 8, 2 resimden 1. Motorola Droid Pro Screen Replacement: adım 8, 2 resimden 2.
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
  9. Motorola Droid Pro Screen Replacement: adım 9, 1 resimden 1.
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
  10. Motorola Droid Pro Screen Replacement: adım 10, 3 resimden 1. Motorola Droid Pro Screen Replacement: adım 10, 3 resimden 2. Motorola Droid Pro Screen Replacement: adım 10, 3 resimden 3.
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
  11. Motorola Droid Pro Screen Replacement: adım 11, 2 resimden 1. Motorola Droid Pro Screen Replacement: adım 11, 2 resimden 2.
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
  12. Motorola Droid Pro Screen Replacement, Screen: adım 12, 2 resimden 1. Motorola Droid Pro Screen Replacement, Screen: adım 12, 2 resimden 2.
    • Use a T4 Torx Screwdriver to remove the (6) 1mm screws.
  13. Motorola Droid Pro Screen Replacement: adım 13, 3 resimden 1. Motorola Droid Pro Screen Replacement: adım 13, 3 resimden 2. Motorola Droid Pro Screen Replacement: adım 13, 3 resimden 3.
    • Using a plastic opening tool or spudger lift the rear screen plate up and pull it off.
  14. Motorola Droid Pro Screen Replacement: adım 14, 3 resimden 1. Motorola Droid Pro Screen Replacement: adım 14, 3 resimden 2. Motorola Droid Pro Screen Replacement: adım 14, 3 resimden 3.
    • Unlock the screen's ribbon cable.
    • The mechanism that locks the ribbon cable in place for the screen is very weak, so be careful.
    • To remove the screen, you have to flip the phone over and let it fall out slowly into your hand. Be careful not to put any tension on the ribbon cable.
    • Then pull the screen away from the ribbon cable connector and it will slide out easily. Do not use excessive force.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kyle Shays
836 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Miles Fall 2015 UMass Dartmouth, Team 1-6, Miles Fall 2015 üyesi
UMASSD-MILES-F15S1G6
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 464
