Ana içeriğe geç
Motorola Droid RAZR Back Cover Replacement
Neye ihtiyacın var
  1. Motorola Droid RAZR Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Droid RAZR Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Back Cover Replacement: adım 2, 3 resimden 1. Motorola Droid RAZR Back Cover Replacement: adım 2, 3 resimden 2. Motorola Droid RAZR Back Cover Replacement: adım 2, 3 resimden 3.
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Back Cover Replacement: adım 3, 3 resimden 1. Motorola Droid RAZR Back Cover Replacement: adım 3, 3 resimden 2. Motorola Droid RAZR Back Cover Replacement: adım 3, 3 resimden 3.
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
David Hodson
154.970 İtibar
127 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 14,457
