Ana içeriğe geç
Giriş
Use this guide to replace the glass on the rear of your Motorola Droid RAZR M.
Aletler
Hiçbir alet belirtilmedi.
Parçalar
  1. Shattered!
    • Shattered!
  2. Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
    • Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
    • Be aware of jumping tiny glass pieces during process. Protect your eyes and area around you. They can get stuck in skin too.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Hemen Alışveriş Yapın
    iPhone X Fix Kits
  4. To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
    • To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
    • Before you take the film off practice the attaching. You will have it hard to reposition after its attached. Same goes with the lens itself, practice before the tape film is off. Once you feel safe to go, peel the film off and go for it!
  5. Done :-)
    • Done :-)
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Alex R
188 İtibar
1 Kılavuz yazıldı
3 Yorum
This is not a razr maxx !!!!
Fausto Lebron - Yanıt
This isn't a Razr Maxx. The back doesn't have glass on a razr maxx.
Alex Tucker - Yanıt
This is Droid razr m . not maxx
Qais Afridi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 5
Her zaman: 7,197
