Ana içeriğe geç
Motorola Droid RAZR M Front Assembly Replacement
Neye ihtiyacın var
  1. Motorola Droid RAZR M Front Assembly Replacement, Front Assembly: adım 1, 3 resimden 1. Motorola Droid RAZR M Front Assembly Replacement, Front Assembly: adım 1, 3 resimden 2. Motorola Droid RAZR M Front Assembly Replacement, Front Assembly: adım 1, 3 resimden 3.
    • Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
    • If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
    • Close the latch once the two cards are removed.
  2. Motorola Droid RAZR M Front Assembly Replacement: adım 2, 3 resimden 1. Motorola Droid RAZR M Front Assembly Replacement: adım 2, 3 resimden 2. Motorola Droid RAZR M Front Assembly Replacement: adım 2, 3 resimden 3.
    • Remove the six 4mm T3 Torx screws. There are 3 on each side of the device.
  3. Motorola Droid RAZR M Front Assembly Replacement: adım 3, 3 resimden 1. Motorola Droid RAZR M Front Assembly Replacement: adım 3, 3 resimden 2. Motorola Droid RAZR M Front Assembly Replacement: adım 3, 3 resimden 3.
    • Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
    • It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
    • The small plastic hooks can break during removal. Be careful that you don't damage them, but it will take some force to get them undone.
    • Once the plastic cover is detached, pull the piece away with your fingers.
  4. Motorola Droid RAZR M Front Assembly Replacement: adım 4, 2 resimden 1. Motorola Droid RAZR M Front Assembly Replacement: adım 4, 2 resimden 2.
    • Remove the three T4 Torx screws. There are three at the bottom of the device.
  5. Motorola Droid RAZR M Front Assembly Replacement: adım 5, 3 resimden 1. Motorola Droid RAZR M Front Assembly Replacement: adım 5, 3 resimden 2. Motorola Droid RAZR M Front Assembly Replacement: adım 5, 3 resimden 3.
    • Using the plastic opening tool, peel away the silver Motorola plate at the top of the phone. There is a fair amount of adhesive underneath, so you may have to pry it from a few different angles.
    • As soon as you can get your finger underneath, pull away the silver plate.
  6. Motorola Droid RAZR M Front Assembly Replacement: adım 6, 2 resimden 1. Motorola Droid RAZR M Front Assembly Replacement: adım 6, 2 resimden 2.
    • Remove the two 7mm T4 Torx screws at the top of the device.
  7. Motorola Droid RAZR M Front Assembly Replacement: adım 7, 3 resimden 1. Motorola Droid RAZR M Front Assembly Replacement: adım 7, 3 resimden 2. Motorola Droid RAZR M Front Assembly Replacement: adım 7, 3 resimden 3.
    • When you detach the front from the back, don't pull the two pieces entirely apart. There is a flat orange wire that connects the two pieces that will be disconnected in the next step.
    • Snap apart the two internal clips located on the top corners of the device, and the two clips in the bottom corners.
    • Run the plastic opening tool around the edge of the entire device to pry apart the front of the phone from the back.
    • There is a small black plastic piece located at the bottom of the front assembly. Do not worry if the strip falls off; just simply snap it back on and proceed.
  8. Motorola Droid RAZR M Front Assembly Replacement: adım 8, 3 resimden 1. Motorola Droid RAZR M Front Assembly Replacement: adım 8, 3 resimden 2. Motorola Droid RAZR M Front Assembly Replacement: adım 8, 3 resimden 3.
    • Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
    • Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
    • Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ethan Look
498 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-1, Amido Spring 2015 Cal Poly, Team 15-1, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G1
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 1,101
