Ana içeriğe geç
Motorola Droid RAZR Maxx Metal Chassis Replacement
Neye ihtiyacın var
  1. Motorola Droid RAZR Maxx Metal Chassis Replacement, Metal Chassis: adım 1, 2 resimden 1. Motorola Droid RAZR Maxx Metal Chassis Replacement, Metal Chassis: adım 1, 2 resimden 2.
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 2, 2 resimden 1. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • After this continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 3, 3 resimden 1. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 3, 3 resimden 2. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 3, 3 resimden 3.
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 4, 1 resimden 1.
    • Looking at the top rectangular hump where the camera is located, you will now use the plastic opening tool to remove the camera cover.
    • With the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
  5. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 5, 3 resimden 1. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 5, 3 resimden 2. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 5, 3 resimden 3.
    • Using the T5 and T4 bit pieces, remove the silver screws located around the rear case of the phone.
    • Remove the three 6.7 mm silver T4 screws that are located at the top of the phone.
    • Remove the five 4.0 mm silver T5 screws that are located near the middle of the phone.
  6. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 6, 1 resimden 1.
    • Using the T4 bit piece remove the three black 4.5 mm screws that are located at the bottom of the phone.
  7. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 7, 3 resimden 1. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 7, 3 resimden 2. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 7, 3 resimden 3.
    • Insert the plastic opening tool between the rear case and motherboard assembly.
    • Using the plastic opening tool, carefully work your way around the phone, freeing the plastic clips.
    • Carefully pull the rear case off the motherboard assembly.
  8. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 8, 2 resimden 1. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 8, 2 resimden 2.
    • Using the tip of the spudger, lift the red silicone cover off the battery terminal screws.
    • Remove the two 3.3mm T5 Torx battery terminal screws.
    • Grab the red battery removal tab and pull the battery out.
    • There might be some adhesive between the battery and motherboard assembly.
  9. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 9, 2 resimden 1. Motorola Droid RAZR Maxx Metal Chassis Replacement: adım 9, 2 resimden 2.
    • Using the T5 bit pieces, remove the silver screws located around the metal chassis.
    • Remove the three 3.5 mm silver T5 screws that are located near the middle of the phone.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nick Kraese
657 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-6, Leahy Fall 2014 USF Tampa, Team 14-6, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G6
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Where are the replacement chassis parts for this phone??? Thanks Joey K
sailorjt1985 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,722
