Ana içeriğe geç
Motorola Droid Speaker Replacement
Neye ihtiyacın var
  1. Motorola Droid Speaker Replacement, Battery: adım 1, 3 resimden 1. Motorola Droid Speaker Replacement, Battery: adım 1, 3 resimden 2. Motorola Droid Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
  2. Motorola Droid Speaker Replacement: adım 2, 1 resimden 1.
    • Grasp the upper left corner of the battery and lift it out of its housing.
  3. Motorola Droid Speaker Replacement, Rear Case: adım 3, 1 resimden 1.
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
  4. Motorola Droid Speaker Replacement: adım 4, 2 resimden 1. Motorola Droid Speaker Replacement: adım 4, 2 resimden 2.
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
  5. Motorola Droid Speaker Replacement: adım 5, 2 resimden 1. Motorola Droid Speaker Replacement: adım 5, 2 resimden 2.
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
  6. Motorola Droid Speaker Replacement: adım 6, 1 resimden 1.
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  7. Motorola Droid Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  8. Motorola Droid Speaker Replacement: adım 8, 1 resimden 1.
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  9. Motorola Droid Speaker Replacement: adım 9, 1 resimden 1.
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  10. Motorola Droid Speaker Replacement: adım 10, 2 resimden 1. Motorola Droid Speaker Replacement: adım 10, 2 resimden 2.
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  11. Motorola Droid Speaker Replacement: adım 11, 2 resimden 1. Motorola Droid Speaker Replacement: adım 11, 2 resimden 2.
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
  12. Motorola Droid Speaker Replacement, Speaker: adım 12, 1 resimden 1.
    • Carefully lift and remove the speaker assembly up out of the phone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Newsom
39.685 İtibar
67 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 16,844
