Ana içeriğe geç
Motorola Droid Turbo Dual LED Flash Board Replacement
Neye ihtiyacın var
  1. Motorola Droid Turbo Dual LED Flash Board Replacement, Rear Case: adım 1, 1 resimden 1.
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Dual LED Flash Board Replacement: adım 2, 2 resimden 1. Motorola Droid Turbo Dual LED Flash Board Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: adım 3, 2 resimden 1. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: adım 3, 2 resimden 2.
    • Use a Jimmy to separate the dual LED flash board from the rear case.
    • The board is secured with some light adhesive, so some force may be required.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geoff Wacker
92.038 İtibar
89 adet Kılavuz yazıldı
1Rehber Yorum
Gostaria se possível alguem tenha o manual de serviço do Moto maxx XT 1225 ou 1254. Porf favor , ddani8260@gmail.com
Daniel Gomes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 1,106
