Ana içeriğe geç
Giriş
Use this guide to replace the dual LED flash board in your Motorola Droid Turbo.
Parçalar
Hiçbir parça belirtilmedi.
  1. Motorola Droid Turbo Dual LED Flash Board Replacement, Rear Case: adım 1, 1 resimden 1.
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    This di not work; I had to use a blow dryer.
    Caroline Downie - Yanıt
  2. Motorola Droid Turbo Dual LED Flash Board Replacement: adım 2, 2 resimden 1. Motorola Droid Turbo Dual LED Flash Board Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
    I had to go around the case, starting on the non-button side, around the top and then the other side. This, unfortunately, pulled on the rear case, pressed the power button and turned the device back on. I would suggest starting on the button side and going around.
    Ryan Helinski - Yanıt
  3. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: adım 3, 2 resimden 1. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: adım 3, 2 resimden 2.
    • Use a Jimmy to separate the dual LED flash board from the rear case.
    • The board is secured with some light adhesive, so some force may be required.
    No parts? Really?
    Rongwey - Yanıt
    What I meant to say was great job! Also I have a question about the adhesive pads holding the flash on. Shouldn't they be replaced as well? My flash wasn't working so I took the back off and cleaned the contacts and put it back together. It worked fine for a couple of days and went back to only blinking. The pads seem to be letting the flash part move with the chop motion to activate the flashlight,
    Rongwey - Yanıt
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geoff Wacker
86.889 İtibar
89 adet Kılavuz yazıldı
Bir Yorum
Gostaria se possível alguem tenha o manual de serviço do Moto maxx XT 1225 ou 1254. Porf favor , ddani8260@gmail.com
Daniel Gomes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 887
