Ana içeriğe geç
Motorola Droid Turbo Front Facing Camera Replacement
Neye ihtiyacın var
  1. Motorola Droid Turbo Front Facing Camera Replacement, Rear Case: adım 1, 1 resimden 1.
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola Droid Turbo Front Facing Camera Replacement: adım 2, 2 resimden 1. Motorola Droid Turbo Front Facing Camera Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola Droid Turbo Front Facing Camera Replacement, Midframe: adım 3, 1 resimden 1.
    • Remove the midframe bezel.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola Droid Turbo Front Facing Camera Replacement: adım 4, 1 resimden 1.
    • Remove the four Torx T5 screws securing the midframe plate.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola Droid Turbo Front Facing Camera Replacement: adım 5, 1 resimden 1.
    • Remove the midframe.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola Droid Turbo Front Facing Camera Replacement, Front Facing Camera: adım 6, 2 resimden 1. Motorola Droid Turbo Front Facing Camera Replacement, Front Facing Camera: adım 6, 2 resimden 2.
    • Use the pointed end of a spudger to flip up the black retaining flap of the front facing camera's ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola Droid Turbo Front Facing Camera Replacement: adım 7, 2 resimden 1. Motorola Droid Turbo Front Facing Camera Replacement: adım 7, 2 resimden 2.
    • Remove the front-facing camera.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Luis Arangu
1.151 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-5, Remmell Spring 2016 USF Tampa, Team 15-5, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S15G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 2,096
