Ana içeriğe geç
Motorola Droid Turbo Headphone Jack Replacement
Neye ihtiyacın var
    1. Motorola Droid Turbo Headphone Jack Replacement, Rear Case: adım 1, 1 resimden 1.
      • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Droid Turbo Headphone Jack Replacement: adım 2, 2 resimden 1. Motorola Droid Turbo Headphone Jack Replacement: adım 2, 2 resimden 2.
      • Use a plastic opening tool to pry the rear case off of the rest of the device.
      • Remove the rear case.
      • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Droid Turbo Headphone Jack Replacement, Midframe: adım 3, 1 resimden 1.
      • Remove the midframe bezel.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Droid Turbo Headphone Jack Replacement: adım 4, 1 resimden 1.
      • Remove the four Torx T5 screws securing the midframe plate.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Droid Turbo Headphone Jack Replacement: adım 5, 1 resimden 1.
      • Remove the midframe.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Droid Turbo Headphone Jack Replacement, Headphone Jack: adım 6, 2 resimden 1. Motorola Droid Turbo Headphone Jack Replacement, Headphone Jack: adım 6, 2 resimden 2.
      • Insert the pointed end of a spudger into the headphone jack, and gently pry the jack up and away from the midframe.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Geoff Wacker
93.084 İtibar
88 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 28
Son 30 gün: 103
Her zaman: 3,881
