Giriş
Use this guide to replace the rear case on your Motorola Droid Turbo.
Neye ihtiyacın var
Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
Use a plastic opening tool to pry the rear case off of the rest of the device.
Remove the rear case.
I had to go around the case, starting on the non-button side, around the top and then the other side. This, unfortunately, pulled on the rear case, pressed the power button and turned the device back on. I would suggest starting on the button side and going around.
This di not work; I had to use a blow dryer.
Caroline Downie - Yanıt
