Ana içeriğe geç
Motorola Droid Turbo Vibrator Replacement
Neye ihtiyacın var
  1. Motorola Droid Turbo Vibrator Replacement, Rear Case: adım 1, 1 resimden 1.
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola Droid Turbo Vibrator Replacement: adım 2, 2 resimden 1. Motorola Droid Turbo Vibrator Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola Droid Turbo Vibrator Replacement, Midframe: adım 3, 1 resimden 1.
    • Remove the midframe bezel.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola Droid Turbo Vibrator Replacement: adım 4, 1 resimden 1.
    • Remove the four Torx T5 screws securing the midframe plate.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola Droid Turbo Vibrator Replacement: adım 5, 1 resimden 1.
    • Remove the midframe.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola Droid Turbo Vibrator Replacement, Vibrator: adım 6, 2 resimden 1. Motorola Droid Turbo Vibrator Replacement, Vibrator: adım 6, 2 resimden 2.
    • Use the pointed end of a spudger to gently pry the vibrator up and away from the midframe.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Geoff Wacker
92.780 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 34
Her zaman: 1,471
