Ana içeriğe geç
Motorola Droid X Camera Replacement
Görüntüleme: 2,8 B
İstatistikleri görüntüle:
Son 24 Saat:
2
Son 7 Gün:
27
Son 30 Gün:
93
Her zaman:
2.849
Yorumlar: 4
4 comments on steps.
Tamamlandı: 1
1 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 1
1 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: 30 dakika
Zorluk: Zor
This guide will instruct the reader how to install a camera module in a Motorola Droid X. This is a rather invasive tutorial that requires much of the phone to be disassembled to get to the camera module, proceed with caution.
Neye ihtiyacın var
Parçalar
Aletler
    1. Motorola Droid X Camera Replacement, Battery: adım 1, 2 resimden 1. Motorola Droid X Camera Replacement, Battery: adım 1, 2 resimden 2.
      • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Droid X Camera Replacement: adım 2, 2 resimden 1. Motorola Droid X Camera Replacement: adım 2, 2 resimden 2.
      • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Droid X Camera Replacement: adım 3, 2 resimden 1. Motorola Droid X Camera Replacement: adım 3, 2 resimden 2.
      • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Droid X Camera Replacement: adım 4, 2 resimden 1. Motorola Droid X Camera Replacement: adım 4, 2 resimden 2.
      • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola Droid X Camera Replacement: adım 5, 1 resimden 1.
      • The battery has been successfully removed.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Droid X Camera Replacement, Motorola Droid X Rear Housing: adım 6, 1 resimden 1.
      • Remove the micro SD card from its connector.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Droid X Camera Replacement: adım 7, 3 resimden 1. Motorola Droid X Camera Replacement: adım 7, 3 resimden 2. Motorola Droid X Camera Replacement: adım 7, 3 resimden 3.
      • Locate the seam between the back case and the end cover on the top edge of the phone.
      • Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left. Once the cover comes off set it aside
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Droid X Camera Replacement: adım 8, 3 resimden 1. Motorola Droid X Camera Replacement: adım 8, 3 resimden 2. Motorola Droid X Camera Replacement: adım 8, 3 resimden 3.
      • Repeat step 2 on the bottom cover.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Droid X Camera Replacement: adım 9, 3 resimden 1. Motorola Droid X Camera Replacement: adım 9, 3 resimden 2. Motorola Droid X Camera Replacement: adım 9, 3 resimden 3.
      • Use a T5 Torx screwdriver to remove the screws in each corner of the phone.
      • The screws are very small so make sure not to lose them.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola Droid X Camera Replacement: adım 10, 2 resimden 1. Motorola Droid X Camera Replacement: adım 10, 2 resimden 2.
      • Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
      FixBot'a Sor
      Yorum Ekle
    6. Motorola Droid X Camera Replacement: adım 11, 2 resimden 1. Motorola Droid X Camera Replacement: adım 11, 2 resimden 2.
      • Identify the screw located in the bottom right corner of the battery case. Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
      FixBot'a Sor
      Yorum Ekle
    7. Motorola Droid X Camera Replacement: adım 12, 2 resimden 1. Motorola Droid X Camera Replacement: adım 12, 2 resimden 2.
      • Locate the seam along the right edge of the phone. Use the prying tool to disconnect the two clips along the edge.
      FixBot'a Sor
      Yorum Ekle
    8. Motorola Droid X Camera Replacement: adım 13, 3 resimden 1. Motorola Droid X Camera Replacement: adım 13, 3 resimden 2. Motorola Droid X Camera Replacement: adım 13, 3 resimden 3.
      • Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
      FixBot'a Sor
      Yorum Ekle
    9. Motorola Droid X Camera Replacement: adım 14, 2 resimden 1. Motorola Droid X Camera Replacement: adım 14, 2 resimden 2.
      • After the clips are detached, remove the back case and set it aside.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Droid X Camera Replacement, Motherboard: adım 15, 1 resimden 1.
      • Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Droid X Camera Replacement: adım 16, 2 resimden 1. Motorola Droid X Camera Replacement: adım 16, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Carefully remove the white connecting wire from the motherboard using tweezers.
      • Use caution, this wire is delicate.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Droid X Camera Replacement: adım 17, 2 resimden 1. Motorola Droid X Camera Replacement: adım 17, 2 resimden 2.
      • Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Droid X Camera Replacement: adım 18, 1 resimden 1.
      • Use the spudger tool to pop the Digitizer cable off of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola Droid X Camera Replacement: adım 19, 1 resimden 1.
      • Carefully flip the small white connector up and away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Motorola Droid X Camera Replacement: adım 20, 1 resimden 1.
      • Gently pull the flat gold cable out from the connector.
      FixBot'a Sor
      Yorum Ekle
    7. Motorola Droid X Camera Replacement: adım 21, 1 resimden 1.
      • Carefully lift the motherboard and camera module up. Do not remove it from the phone!
      FixBot'a Sor
      Yorum Ekle
    8. Motorola Droid X Camera Replacement: adım 22, 1 resimden 1.
      • Using the spudger tool, pop the black cable connector off of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    9. Motorola Droid X Camera Replacement: adım 23, 1 resimden 1.
      • It is to safe remove the motherboard from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Droid X Camera Replacement, Camera: adım 24, 1 resimden 1.
      • Gently peel the camera's orange and gold connection cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Droid X Camera Replacement: adım 25, 1 resimden 1.
      • Remove the black electrical tape covering the cameras connection cable.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Droid X Camera Replacement: adım 26, 1 resimden 1.
      • Flip up the small white connector. Then gently pull the orange cable out of the connecter.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Droid X Camera Replacement: adım 27, 1 resimden 1.
      • Reconnect the camera module by pushing the black end of the flat cable on the camera module into the white connector on the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yazar
ile
Sam Johnston
576 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-40, Regan Fall 2012 Cal Poly, Team 18-40, Regan Fall 2012 üyesi
CPSU-REGAN-F12S18G40
3 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 27
Son 30 gün: 93
Her zaman: 2,849
