Ana içeriğe geç
Motorola Droid X2 Motherboard Replacement
Neye ihtiyacın var
  1. Motorola Droid X2 Motherboard Replacement, Battery: adım 1, 3 resimden 1. Motorola Droid X2 Motherboard Replacement, Battery: adım 1, 3 resimden 2. Motorola Droid X2 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the plastic case off of the back of the phone, exposing the battery.
  2. Motorola Droid X2 Motherboard Replacement: adım 2, 3 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 2, 3 resimden 2. Motorola Droid X2 Motherboard Replacement: adım 2, 3 resimden 3.
    • Pull up on the red battery release tab and pull the battery out of the phone.
  3. Motorola Droid X2 Motherboard Replacement, Motherboard: adım 3, 2 resimden 1. Motorola Droid X2 Motherboard Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
    • Be careful to not strip any screws.
  4. Motorola Droid X2 Motherboard Replacement: adım 4, 3 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 4, 3 resimden 2. Motorola Droid X2 Motherboard Replacement: adım 4, 3 resimden 3.
    • Using a prying tool, snap off the front casing on the top and bottom of the phone.
    • Be careful not to lose the small rubber piece that sits over the microphone.
  5. Motorola Droid X2 Motherboard Replacement: adım 5, 2 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
  6. Motorola Droid X2 Motherboard Replacement: adım 6, 3 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 6, 3 resimden 2. Motorola Droid X2 Motherboard Replacement: adım 6, 3 resimden 3.
    • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
  7. Motorola Droid X2 Motherboard Replacement: adım 7, 3 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 7, 3 resimden 2. Motorola Droid X2 Motherboard Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, remove the white wire at the top of the phone near the camera.
  8. Motorola Droid X2 Motherboard Replacement: adım 8, 2 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
  9. Motorola Droid X2 Motherboard Replacement: adım 9, 2 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 9, 2 resimden 2.
    • Using tweezers, removed the white electrical tape on the motherboard.
  10. Motorola Droid X2 Motherboard Replacement: adım 10, 2 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 10, 2 resimden 2.
    • Using the plastic opening tool, lift up to remove the connector.
  11. Motorola Droid X2 Motherboard Replacement: adım 11, 2 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 11, 2 resimden 2.
    • Using a pry tool, lift the jawbone connector.
  12. Motorola Droid X2 Motherboard Replacement: adım 12, 2 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 12, 2 resimden 2.
    • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
  13. Motorola Droid X2 Motherboard Replacement: adım 13, 3 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 13, 3 resimden 2. Motorola Droid X2 Motherboard Replacement: adım 13, 3 resimden 3.
    • Use a spudger to disconnect the cable connector.
  14. Motorola Droid X2 Motherboard Replacement: adım 14, 3 resimden 1. Motorola Droid X2 Motherboard Replacement: adım 14, 3 resimden 2. Motorola Droid X2 Motherboard Replacement: adım 14, 3 resimden 3.
    • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Mak
658 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Miles Fall 2014 UMass Dartmouth, Team 4-3, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 798
