Ana içeriğe geç
Motorola Droid X2 Screen Replacement
Neye ihtiyacın var
  1. Motorola Droid X2 Screen Replacement, Battery: adım 1, 3 resimden 1. Motorola Droid X2 Screen Replacement, Battery: adım 1, 3 resimden 2. Motorola Droid X2 Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the plastic case off of the back of the phone, exposing the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola Droid X2 Screen Replacement: adım 2, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 2, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 2, 3 resimden 3.
    • Pull up on the red battery release tab and pull the battery out of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola Droid X2 Screen Replacement, Motherboard: adım 3, 2 resimden 1. Motorola Droid X2 Screen Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
    • Be careful to not strip any screws.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola Droid X2 Screen Replacement: adım 4, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 4, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 4, 3 resimden 3.
    • Using a prying tool, snap off the front casing on the top and bottom of the phone.
    • Be careful not to lose the small rubber piece that sits over the microphone.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola Droid X2 Screen Replacement: adım 5, 2 resimden 1. Motorola Droid X2 Screen Replacement: adım 5, 2 resimden 2.
    • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola Droid X2 Screen Replacement: adım 6, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 6, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 6, 3 resimden 3.
    • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola Droid X2 Screen Replacement: adım 7, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 7, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the white wire at the top of the phone near the camera.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola Droid X2 Screen Replacement: adım 8, 2 resimden 1. Motorola Droid X2 Screen Replacement: adım 8, 2 resimden 2.
    • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
    FixBot'a Sor
    Yorum Ekle
  9. Motorola Droid X2 Screen Replacement: adım 9, 2 resimden 1. Motorola Droid X2 Screen Replacement: adım 9, 2 resimden 2.
    • Using tweezers, removed the white electrical tape on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. Motorola Droid X2 Screen Replacement: adım 10, 2 resimden 1. Motorola Droid X2 Screen Replacement: adım 10, 2 resimden 2.
    • Using the plastic opening tool, lift up to remove the connector.
    FixBot'a Sor
    Yorum Ekle
  11. Motorola Droid X2 Screen Replacement: adım 11, 2 resimden 1. Motorola Droid X2 Screen Replacement: adım 11, 2 resimden 2.
    • Using a pry tool, lift the jawbone connector.
    FixBot'a Sor
    Yorum Ekle
  12. Motorola Droid X2 Screen Replacement: adım 12, 2 resimden 1. Motorola Droid X2 Screen Replacement: adım 12, 2 resimden 2.
    • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
    FixBot'a Sor
    Yorum Ekle
  13. Motorola Droid X2 Screen Replacement: adım 13, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 13, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 13, 3 resimden 3.
    • Use a spudger to disconnect the cable connector.
    FixBot'a Sor
    Yorum Ekle
  14. Motorola Droid X2 Screen Replacement: adım 14, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 14, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 14, 3 resimden 3.
    • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
    FixBot'a Sor
    Yorum Ekle
  15. Motorola Droid X2 Screen Replacement, Screen: adım 15, 2 resimden 1. Motorola Droid X2 Screen Replacement, Screen: adım 15, 2 resimden 2.
    • Remove the 4 screws using a T-3 torques.. These screws are 2.40 mm in length.
    • Be careful to not strip the screws.
    FixBot'a Sor
    Yorum Ekle
  16. Motorola Droid X2 Screen Replacement: adım 16, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 16, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 16, 3 resimden 3.
    • Using tweezers, remove the white tape to reveal the connector
    FixBot'a Sor
    Yorum Ekle
  17. Motorola Droid X2 Screen Replacement: adım 17, 1 resimden 1.
    • Using the plastic opening tool, lift the jawbone connector.
    FixBot'a Sor
    Yorum Ekle
  18. Motorola Droid X2 Screen Replacement: adım 18, 2 resimden 1. Motorola Droid X2 Screen Replacement: adım 18, 2 resimden 2.
    • Using tweezers, remove cable from the connector
    FixBot'a Sor
    Yorum Ekle
  19. Motorola Droid X2 Screen Replacement: adım 19, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 19, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 19, 3 resimden 3.
    • Using a plastic opening tool, lift the connector from the device
    FixBot'a Sor
    Yorum Ekle
  20. Motorola Droid X2 Screen Replacement: adım 20, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 20, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 20, 3 resimden 3.
    • Lift the ribbon from the device
    • This does require some effort to remove.
    FixBot'a Sor
    Yorum Ekle
  21. Motorola Droid X2 Screen Replacement: adım 21, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 21, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 21, 3 resimden 3.
    • Lift the screen off of the device
    FixBot'a Sor
    Yorum Ekle
  22. Motorola Droid X2 Screen Replacement: adım 22, 2 resimden 1. Motorola Droid X2 Screen Replacement: adım 22, 2 resimden 2.
    • Using a heat gun, gently heat the edges of the screen
    • Be careful as overheating can damage the electronics.
    • The screen will be hot after.
    FixBot'a Sor
    Yorum Ekle
  23. Motorola Droid X2 Screen Replacement: adım 23, 3 resimden 1. Motorola Droid X2 Screen Replacement: adım 23, 3 resimden 2. Motorola Droid X2 Screen Replacement: adım 23, 3 resimden 3.
    • Lift the screen from the frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Aaron Mak
658 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Miles Fall 2014 UMass Dartmouth, Team 4-3, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G3
3 Üyeler
16 adet Kılavuz yazıldı
1Rehber Yorum
I recently ran into an interesting situation with the Droid X2 at my repair shop. I know this is an older device, but this is still a very important piece of information: there are 2 different types of digitizers and 2 different types of LCD's, depending on the Droid X2's transceiver number. Type A digitizer has a smaller front row button connector, Type B is larger. Same with the LCD, there is a Type A small connector and a Type B larger connector. Under the battery on the barcode sticker, right below the "MB870" barcode is the transceiver number, starting with "SJUG" and ending in either 6250 (type A) or 6065 (type B). Anyone buying a replacement LCD or digitizer needs to know which one to get, or else the connectors won't fit.
Andrew F - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 42
Her zaman: 1,512
