Ana içeriğe geç
Motorola E815 Keypad Replacement
Neye ihtiyacın var
  1. Motorola E815 Keypad Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Motorola E815 Keypad Replacement: adım 2, 1 resimden 1.
    • Remove the back cover by pulling it away from the phone.
  3. Motorola E815 Keypad Replacement: adım 3, 2 resimden 1. Motorola E815 Keypad Replacement: adım 3, 2 resimden 2.
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Motorola E815 Keypad Replacement, Disassembling Motorola E815 Antenna: adım 4, 1 resimden 1.
    • Locate the antenna port on the top of the phone.
    Removing Antenna Only
    Zoie E - Yanıt
  5. Motorola E815 Keypad Replacement: adım 5, 2 resimden 1. Motorola E815 Keypad Replacement: adım 5, 2 resimden 2.
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Motorola E815 Keypad Replacement, Keypad: adım 6, 1 resimden 1.
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using a T6 Screwdriver.
  7. Motorola E815 Keypad Replacement: adım 7, 3 resimden 1. Motorola E815 Keypad Replacement: adım 7, 3 resimden 2. Motorola E815 Keypad Replacement: adım 7, 3 resimden 3.
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Carefully detach the two sections of the phone.
  8. Motorola E815 Keypad Replacement: adım 8, 3 resimden 1. Motorola E815 Keypad Replacement: adım 8, 3 resimden 2. Motorola E815 Keypad Replacement: adım 8, 3 resimden 3.
    • Using the blue pry tool, carefully pull the keypad frame away from the keypad.
    • Gently remove the keypad frame from the keypad.
    • Lift the silicone keypad cover off.
  9. Motorola E815 Keypad Replacement: adım 9, 2 resimden 1. Motorola E815 Keypad Replacement: adım 9, 2 resimden 2.
    • Rotate the phone around so that you are looking at the battery cavity.
    • Locate the screws on the bottom base of the phone.
  10. Motorola E815 Keypad Replacement: adım 10, 2 resimden 1. Motorola E815 Keypad Replacement: adım 10, 2 resimden 2.
    • Rotate the phone back to the front side.
    • Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
  11. Motorola E815 Keypad Replacement: adım 11, 3 resimden 1. Motorola E815 Keypad Replacement: adım 11, 3 resimden 2. Motorola E815 Keypad Replacement: adım 11, 3 resimden 3.
    • Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
    • Separate the keypad from the circuit board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zoie E
603 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-8, Forte Winter 2011 Cal Poly, Team 14-8, Forte Winter 2011 üyesi
CPSU-FORTE-W11S14G8
5 Üyeler
2 Yorum
We should have a motherboard replacement.
Santi12008 - Yanıt
We need to fullify more this content.
Santi12008 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,085
