Ana içeriğe geç
Motorola E815 interiorscreen replacement
Neye ihtiyacın var
  1. Motorola E815 interiorscreen replacement, Battery: adım 1, 1 resimden 1.
    • Locate the back cover release slide.
    • Use your finger to slide it down.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola E815 interiorscreen replacement: adım 2, 1 resimden 1.
    • Remove the back cover by pulling it away from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola E815 interiorscreen replacement: adım 3, 2 resimden 1. Motorola E815 interiorscreen replacement: adım 3, 2 resimden 2.
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola E815 interiorscreen replacement, Disassembling Motorola E815 Antenna: adım 4, 1 resimden 1.
    • Locate the antenna port on the top of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola E815 interiorscreen replacement: adım 5, 2 resimden 1. Motorola E815 interiorscreen replacement: adım 5, 2 resimden 2.
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola E815 interiorscreen replacement, Front Screen: adım 6, 3 resimden 1. Motorola E815 interiorscreen replacement, Front Screen: adım 6, 3 resimden 2. Motorola E815 interiorscreen replacement, Front Screen: adım 6, 3 resimden 3.
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using your T6 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola E815 interiorscreen replacement: adım 7, 3 resimden 1. Motorola E815 interiorscreen replacement: adım 7, 3 resimden 2. Motorola E815 interiorscreen replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Grasp the top of the phone near the speaker.
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Detach the top section of the phone from the keypad section.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola E815 interiorscreen replacement: adım 8, 2 resimden 1. Motorola E815 interiorscreen replacement: adım 8, 2 resimden 2.
    • Carefully insert the blue pry tool into the notch between the two halves of the top section of the phone.
    • Gently pry the two halves apart.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola E815 interiorscreen replacement: adım 9, 1 resimden 1.
    • Rotate the top section of the phone around so that you are looking at the outer screen.
    • Disconnect the cover from the outer screen side of the phone.
    FixBot'a Sor
    Yorum Ekle
  10. Motorola E815 interiorscreen replacement: adım 10, 3 resimden 1. Motorola E815 interiorscreen replacement: adım 10, 3 resimden 2. Motorola E815 interiorscreen replacement: adım 10, 3 resimden 3.
    • Rotate the top section of the phone around so you are looking at the large screen.
    • Using your fingers, lift the protector off of the screen.
    FixBot'a Sor
    Yorum Ekle
  11. Motorola E815 interiorscreen replacement: adım 11, 1 resimden 1.
    • Using the blue pry tool, gently remove the screen cover.
    • Since it is glued into place, it may take some maneuvering to remove.
    FixBot'a Sor
    Yorum Ekle
  12. Motorola E815 interiorscreen replacement: adım 12, 3 resimden 1. Motorola E815 interiorscreen replacement: adım 12, 3 resimden 2. Motorola E815 interiorscreen replacement: adım 12, 3 resimden 3.
    • Turn the phone so that you can see the side metal clasps.
    • Using the blue lifter tool, snap the metal clasps off of screen body.
    • Proceed to snap all four corners of the metal cover off of the screen body.
    FixBot'a Sor
    Yorum Ekle
  13. Motorola E815 interiorscreen replacement: adım 13, 2 resimden 1. Motorola E815 interiorscreen replacement: adım 13, 2 resimden 2.
    • Using tweezers, gently detach the brown connecting strip from the back of the screen.
    • Separate the screen from the phone frame.
    • The front screen can now be accessed and replaced!
    FixBot'a Sor
    Yorum Ekle
  14. Motorola E815 interiorscreen replacement, Inside Screen: adım 14, 1 resimden 1.
    • The inside screen can now be accessed for repair or replacement!
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zoie E
603 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-8, Forte Winter 2011 Cal Poly, Team 14-8, Forte Winter 2011 üyesi
CPSU-FORTE-W11S14G8
5 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 2,562
