Ana içeriğe geç
Motorola Edge (2021) Front-Facing Camera module Replacement
Neye ihtiyacın var
  1. Motorola Edge (2021) Front-Facing Camera module Replacement, Front-Facing Camera: adım 1, 1 resimden 1.
    • Remove the back cover of the smartphone.
  2. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 2, 1 resimden 1.
    • Use two iOpeners to heat up the glue beneath the back-plate.
  3. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 3, 3 resimden 1. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 3, 3 resimden 2. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 3, 3 resimden 3.
    • Wedge the iFixit Opening Pick in between the cracks of the smartphone's backplate.
    • Slide the opening tool along the sides of the phone until the glue is separated from the back-plate.
  4. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 4, 2 resimden 1. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 4, 2 resimden 2.
    • Next, use the Phillips #00 Screwdriver to unscrew the motherboard/camera casing. Be sure to check under the glue for any unseen screws.
  5. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 5, 2 resimden 1. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 5, 2 resimden 2.
    • After you're done unscrewing, use the iFixit Opening Tool to carefully pry open the casing.
  6. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 6, 1 resimden 1.
    • This is the front facing camera module.
  7. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 7, 2 resimden 1. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 7, 2 resimden 2.
    • Using the iFixit Opening Tool, carefully remove the camera module.
  8. Motorola Edge (2021) Front-Facing Camera module Replacement: adım 8, 1 resimden 1.
    • Congratulations, you have successfully removed the front facing camera module for your Motorola Edge.
Sonuç
Jaier
339 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 281
