Giriş
Guide to replace a broken screen on Moto G30 phones. On this model, the label on the back says "Type: MC391".
Neye ihtiyacın var
Unclip the plastic back cover using any tool you like (mediators, sprudgers, Jimmy...)
Slighly move the back cover in order to unscrew the plastic piece behind it
Remove the 9 small Philips-head screws inside
You will also have to remove small black adhesive pieces to be able to remove the part completely
Once the black plastic cover piece is removed, unplug the cable holding the back panel
Once this flex cable unplugged, lift the back panel completely
Unplug both battery and display connectors
Battery on the right
Display in the middle
You can use the opening tool as lever.
Unscrew the cover at the bottom of the phone
7 small Philips head screws to remove
A little black adhesive to peel off around the edges
Unplug the connector
Steps 9 and 10 are only useful if you order the display without its frame. Move on to step 11 if you intend to order the display with its frame
Heat up to help unglue the screen
Unglue the display from the chassis
I could not properly unglue with a cutter blade on the side. My technique is simpler and more brutal: I pushed the display away from the connector hole, with a rigid tool.
Replug the battery pack
Test the battery voltage on the test point to the left of the connector (the ground is everywhere on the metal chassis): it must be between 3.6 and 4.2 V
Unglue the screen-USB-motherboard flex cable from your broken screen, and replug the bottom USB board with the top motherboard
Turn on phone with Power On + Up buttons
Plug it to the computer with an USB-C cable
Type "lsusb" in a shell
If you can read something like "22b8:XXXX Motorola PCS moto g(30)", congratulations: your motherboard still lives
Once your phone has been successfully torn down and tested, it is time to order the replacement screen
The part will cost you around 15-20€. You can find it here for instance
Two choices: ordering the display pre-assembled on a new frame, or ordering it without
I recommend pre-assembled display, it will be more sturdy and less subject to breaking
While waiting for your order, don’t forget to store your parts and small screw properly
If you ordered the display pre-assembled on a frame, you will have to move all the components from the old chassis to the new one
You will find the small button panel on the chassis side, unglue it carefully
Start by ungluing the black tape covering it
Unplug the button connector from the main PCB
Unglue the button flex board carefully
Glue it on the new chassis
Unscrew both PCB
The top one is held by 2 screws
The bottom one is help by one screw
Slide the top PCB out of the chassis
Under it, there is a small undefined module, and an opaque sticker
Get the module out of its casing
Unglue the sticker under it
Replace both module and sticker on the other side
Remove the bottom PCB
The haptic module is under it, unglue it carefully
Start by the connector side
Once the connector side is lifted, it is easier to get to the rest of the module and unglue it
Try to salvage the stickers and glue them back to the new frame
You can also use new stickers
The pink sticker is a very thin thermal pad, you can replace it by thermal paste
The orange sticker is a tape copper foil
I don’t know how to replace the metallic grey thing, it is probably use for a better RF shielding
Insert the top PCB into the new frame
Don’t forget to move the button PCB small connector out of the way, it could get stuck under the board
Plug the elements back
Top and bottom screen module connectors
Right-side antenna cable
Small button PCB connector
Screw the boards back in place
Replug the back cover connector
A step you don’t see on the pictures because I forgot
Rescrew the two PCB covers
Clip the cover back in place
Insert the SIM card holder
Unfortunately, my phone is bricked, so I could never turn it on and test the new screen. I hope you will get more luck than me!
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
