Ana içeriğe geç
Motorola Hyper Android Phone Charging port Replacement
Neye ihtiyacın var
  1. Motorola Hyper Android Phone Charging port Replacement, Finding the seam  to remove.: adım 1, 1 resimden 1.
    • Charging port replacement
  2. Motorola Hyper Android Phone Charging port Replacement, Teardown - Remove sim tray: adım 2, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Teardown - Remove sim tray: adım 2, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Teardown - Remove sim tray: adım 2, 3 resimden 3.
    • Use a heat gun or hair dryer to soften the adhesive on the rear cover
  3. Motorola Hyper Android Phone Charging port Replacement: adım 3, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement: adım 3, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement: adım 3, 3 resimden 3.
    • Start at the camera and go around the edge with an Opening Pick. Pry the last bit around the camera.
  4. Motorola Hyper Android Phone Charging port Replacement, Opening cover: adım 4, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Opening cover: adım 4, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Opening cover: adım 4, 3 resimden 3.
    • Open case from the on button side face down. You will need a T4 bit driver.
  5. Motorola Hyper Android Phone Charging port Replacement, Remove  screws for vent: adım 5, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Remove  screws for vent: adım 5, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Remove  screws for vent: adım 5, 3 resimden 3.
    • Remove 6 T4 screws. Remove mini fan vent.
  6. Motorola Hyper Android Phone Charging port Replacement, Remove charging wires: adım 6, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Remove charging wires: adım 6, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Remove charging wires: adım 6, 3 resimden 3.
    • Pry off the black and white wires with a pry tool. Remove Philips screw.
  7. Motorola Hyper Android Phone Charging port Replacement, Remove charge port: adım 7, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Remove charge port: adım 7, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Remove charge port: adım 7, 3 resimden 3.
    • Remove and replace the charge port with new one.
  8. Motorola Hyper Android Phone Charging port Replacement, Assembly: adım 8, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Assembly: adım 8, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Assembly: adım 8, 3 resimden 3.
    • Install items in reverse order
  9. Motorola Hyper Android Phone Charging port Replacement, Remove old gasket material: adım 9, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Remove old gasket material: adım 9, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Remove old gasket material: adım 9, 3 resimden 3.
    • Clean all the gasket off.
    • There is only room for one layer, for a smooth cover fit.
  10. Motorola Hyper Android Phone Charging port Replacement, Remove finger print reader cable: adım 10, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Remove finger print reader cable: adım 10, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Remove finger print reader cable: adım 10, 3 resimden 3.
    • Remove finger print reader cable to install new cover gasket. surface must be clean so the cover sits tight with no gaps.
  11. Motorola Hyper Android Phone Charging port Replacement, Install gasket: adım 11, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Install gasket: adım 11, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Install gasket: adım 11, 3 resimden 3.
    • Make sure the gasket is firmly in place.
  12. Motorola Hyper Android Phone Charging port Replacement, Replace FPR cable: adım 12, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Replace FPR cable: adım 12, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Replace FPR cable: adım 12, 3 resimden 3.
    • Install FPR cable.
    • Install the keep.
    • Put tape on the cover to align the edges.
  13. Motorola Hyper Android Phone Charging port Replacement, Finish installing cover: adım 13, 3 resimden 1. Motorola Hyper Android Phone Charging port Replacement, Finish installing cover: adım 13, 3 resimden 2. Motorola Hyper Android Phone Charging port Replacement, Finish installing cover: adım 13, 3 resimden 3.
    • Tape helps align cover for a smooth install.
    • Press the cover on to seal.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
wes zab
277 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 67
Her zaman: 897
