Ana içeriğe geç
Motorola Krzr K1m keyboard repalcement
Neye ihtiyacın var
  1. Motorola Krzr K1m keyboard repalcement, Keypad: adım 1, 2 resimden 1. Motorola Krzr K1m keyboard repalcement, Keypad: adım 1, 2 resimden 2.
    • Remove the battery with your fingers by pulling the battery from the top corners labeled "Pull Here" located on the left and right side of the top of the battery.
    • Remove the battery.
  2. Motorola Krzr K1m keyboard repalcement: adım 2, 3 resimden 1. Motorola Krzr K1m keyboard repalcement: adım 2, 3 resimden 2. Motorola Krzr K1m keyboard repalcement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    Satın Al
    • To begin detaching the battery dock, unscrew the 4 black screws on each corner of the phone with the T5 Torx Screwdriver.
    • Lift up the battery dock where the hinges are located. Carefully insert the T5 Torx Screwdriver in between the battery dock and the back plate of the battery. (See the picture to locate the hinges)
    • Remove the battery dock by popping it up with The Spudger.
  3. Motorola Krzr K1m keyboard repalcement: adım 3, 3 resimden 1. Motorola Krzr K1m keyboard repalcement: adım 3, 3 resimden 2. Motorola Krzr K1m keyboard repalcement: adım 3, 3 resimden 3.
    • To remove the chip board, first unplug the flex cable from the logic board with tweezers.
    • Lift up the logic board from the bottom flip with your fingers.
    • Remove the logic board.
  4. Motorola Krzr K1m keyboard repalcement: adım 4, 2 resimden 1. Motorola Krzr K1m keyboard repalcement: adım 4, 2 resimden 2.
    • Gently pop off the keypad with your fingers.
    • Once the keypad is removed, follow all of the steps in reverse order to replace the old keypad with the new keypad.
Sonuç
Jennifer Hudiono
42 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-1, Forte Winter 2010 Cal Poly, Team 11-1, Forte Winter 2010 üyesi
CPSU-FORTE-W10S11G1
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 4,395
