Ana içeriğe geç
Motorola Lapdock 100 Screen Replacement
Neye ihtiyacın var
  1. Motorola Lapdock 100 Screen Replacement, Lower Case: adım 1, 2 resimden 1. Motorola Lapdock 100 Screen Replacement, Lower Case: adım 1, 2 resimden 2.
    • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
    • You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
  2. Motorola Lapdock 100 Screen Replacement: adım 2, 1 resimden 1.
    • You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
  3. Motorola Lapdock 100 Screen Replacement: adım 3, 1 resimden 1.
    • Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
  4. Motorola Lapdock 100 Screen Replacement: adım 4, 2 resimden 1. Motorola Lapdock 100 Screen Replacement: adım 4, 2 resimden 2.
    • Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
  5. Motorola Lapdock 100 Screen Replacement: adım 5, 2 resimden 1. Motorola Lapdock 100 Screen Replacement: adım 5, 2 resimden 2.
    • After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
  6. Motorola Lapdock 100 Screen Replacement: adım 6, 3 resimden 1. Motorola Lapdock 100 Screen Replacement: adım 6, 3 resimden 2. Motorola Lapdock 100 Screen Replacement: adım 6, 3 resimden 3.
    • Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
  7. Motorola Lapdock 100 Screen Replacement: adım 7, 2 resimden 1. Motorola Lapdock 100 Screen Replacement: adım 7, 2 resimden 2.
    • Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
  8. Motorola Lapdock 100 Screen Replacement, Battery: adım 8, 2 resimden 1. Motorola Lapdock 100 Screen Replacement, Battery: adım 8, 2 resimden 2.
    • Unplug battery from motherboard.
  9. Motorola Lapdock 100 Screen Replacement: adım 9, 1 resimden 1.
    • Remove the battery.
  10. Motorola Lapdock 100 Screen Replacement, Screen: adım 10, 2 resimden 1. Motorola Lapdock 100 Screen Replacement, Screen: adım 10, 2 resimden 2.
    • Disconnect the two wires that attach to the screen.
  11. Motorola Lapdock 100 Screen Replacement: adım 11, 1 resimden 1.
    • Now flip the lapdock back over. Using a plastic prying tool, unclip and remove the small plastic cover at the top of the lapdock.
  12. Motorola Lapdock 100 Screen Replacement: adım 12, 1 resimden 1.
    • Insert wisdom here.
  13. Motorola Lapdock 100 Screen Replacement: adım 13, 1 resimden 1.
  14. Motorola Lapdock 100 Screen Replacement: adım 14, 2 resimden 1. Motorola Lapdock 100 Screen Replacement: adım 14, 2 resimden 2.
    • Remove the four 3.5 mm long phillips head screws from the two screen flanges holding the screen.
    • The screen should be free from the lapdock after doing the prior step.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 802
