Ana içeriğe geç
Motorola MBP667CONNECT Battery Replacement
Neye ihtiyacın var
  1. Motorola MBP667CONNECT Battery Replacement, Battery: adım 1, 1 resimden 1.
    • The battery casing is on the back of the monitor housing.
  2. Motorola MBP667CONNECT Battery Replacement: adım 2, 2 resimden 1. Motorola MBP667CONNECT Battery Replacement: adım 2, 2 resimden 2.
    • Notice the little crevice at the bottom of the baby monitor. This is how the lid is removed. Simply put pressure with your finger to the crevice and lift.
    • Remove the battery casing lid from the back of the monitor housing.
  3. Motorola MBP667CONNECT Battery Replacement: adım 3, 1 resimden 1.
    • There is a plastic part connecting the wires of the battery to the device.
    • Disconnect the battery wiring from the monitor battery connection.
  4. Motorola MBP667CONNECT Battery Replacement: adım 4, 1 resimden 1.
    • Remove and discard the old battery and replace it with a new battery.
Sonuç
Kyle Kramer
255 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
just bought the battery linked and it has a slightly different, incompatible fitting. If i find one that works I’ll post…
Alex Chassy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 5,037
