Ana içeriğe geç
Motorola MBP667CONNECT Camera Stand Replacement
Neye ihtiyacın var
  1. Motorola MBP667CONNECT Camera Stand Replacement, Camera Stand: adım 1, 2 resimden 1. Motorola MBP667CONNECT Camera Stand Replacement, Camera Stand: adım 1, 2 resimden 2.
    • Remove two 5 mm Phillips #1 screws from the bottom of the camera stand.
  2. Motorola MBP667CONNECT Camera Stand Replacement: adım 2, 1 resimden 1.
    • Use a nylon spudger to remove the casing.
  3. Motorola MBP667CONNECT Camera Stand Replacement: adım 3, 1 resimden 1.
    • Remove the two 5 mm Phillips #1 screws attached to the black plastic under the casing.
  4. Motorola MBP667CONNECT Camera Stand Replacement: adım 4, 2 resimden 1. Motorola MBP667CONNECT Camera Stand Replacement: adım 4, 2 resimden 2.
    • Remove the black circular plastic part.
  5. Motorola MBP667CONNECT Camera Stand Replacement: adım 5, 1 resimden 1.
    • Remove the white plastic wire housing beneath the black plastic.
  6. Motorola MBP667CONNECT Camera Stand Replacement: adım 6, 2 resimden 1. Motorola MBP667CONNECT Camera Stand Replacement: adım 6, 2 resimden 2.
    • Now, remove the bottom of the stand by pulling it from the camera.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 561
