Ana içeriğe geç
Motorola MBP667CONNECT Circuit Board Replacement
Neye ihtiyacın var
  1. Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 1. Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 2. Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 3.
    • Remove the two 5 mm Phillips #1 screws on the back of the camera.
    • Use a nylon spudger to remove the casing.
  2. Motorola MBP667CONNECT Circuit Board Replacement: adım 2, 3 resimden 1. Motorola MBP667CONNECT Circuit Board Replacement: adım 2, 3 resimden 2. Motorola MBP667CONNECT Circuit Board Replacement: adım 2, 3 resimden 3.
    • Remove the brackets by the speaker on the front side of the camera using the metal spudger.
    • Continue to use the metal spudger to carefully disconnect remaining brackets from casing.
    • Remove the two 5mm Phillips #1 screws on the backside of the camera.
  3. Motorola MBP667CONNECT Circuit Board Replacement: adım 3, 3 resimden 1. Motorola MBP667CONNECT Circuit Board Replacement: adım 3, 3 resimden 2. Motorola MBP667CONNECT Circuit Board Replacement: adım 3, 3 resimden 3.
    • Use the nylon spudger to remove the circuit board from the plastic casing for the backside of the camera.
    • Remove the two 5 mm Phillips #1 screws on the black circle receiver housing.
    • Now that the black circle is detached, use a nylon spudger to remove the white plastic circle from the casing.
  4. Motorola MBP667CONNECT Circuit Board Replacement: adım 4, 2 resimden 1. Motorola MBP667CONNECT Circuit Board Replacement: adım 4, 2 resimden 2.
    • You will now be able to carefully pull the receiver wire through the gap in the casing.
Sonuç
Jordan Webb
109 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 383
