Ana içeriğe geç
Motorola MBP667CONNECT Speaker Replacement
Neye ihtiyacın var
  1. Motorola MBP667CONNECT Speaker Replacement, Camera Stand: adım 1, 2 resimden 1. Motorola MBP667CONNECT Speaker Replacement, Camera Stand: adım 1, 2 resimden 2.
    • Remove two 5 mm Phillips #1 screws from the bottom of the camera stand.
  2. Motorola MBP667CONNECT Speaker Replacement: adım 2, 1 resimden 1.
    • Use a nylon spudger to remove the casing.
  3. Motorola MBP667CONNECT Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the two 5 mm Phillips #1 screws attached to the black plastic under the casing.
  4. Motorola MBP667CONNECT Speaker Replacement: adım 4, 2 resimden 1. Motorola MBP667CONNECT Speaker Replacement: adım 4, 2 resimden 2.
    • Remove the black circular plastic part.
  5. Motorola MBP667CONNECT Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the white plastic wire housing beneath the black plastic.
  6. Motorola MBP667CONNECT Speaker Replacement: adım 6, 2 resimden 1. Motorola MBP667CONNECT Speaker Replacement: adım 6, 2 resimden 2.
    • Now, remove the bottom of the stand by pulling it from the camera.
  7. Motorola MBP667CONNECT Speaker Replacement, Speaker: adım 7, 3 resimden 1. Motorola MBP667CONNECT Speaker Replacement, Speaker: adım 7, 3 resimden 2. Motorola MBP667CONNECT Speaker Replacement, Speaker: adım 7, 3 resimden 3.
    • Remove the Phillips #1 screws on the back of the device.
    • Use a nylon spudger to remove the casing. This will separate the frontside of the camera from the backside.
  8. Motorola MBP667CONNECT Speaker Replacement: adım 8, 2 resimden 1. Motorola MBP667CONNECT Speaker Replacement: adım 8, 2 resimden 2.
    • Now locate the brackets by the speaker on the frontside of the camera and use the metal spudger to carefully disconnect from casing.
    • Continue to use the metal spudger to carefully disconnect the remaining brackets from the casing.
  9. Motorola MBP667CONNECT Speaker Replacement: adım 9, 2 resimden 1. Motorola MBP667CONNECT Speaker Replacement: adım 9, 2 resimden 2.
    • Using the soldering iron, desolder the speaker wires that are attached to the circuit board.
    • Use caution while handling the soldering iron. This tool gets very hot!
    • After desoldering the speaker wires, remove the wires from the circuit board.
    • Thread the wires from the new speaker wires through the holes in the circuit board. Using the soldering iron, re-solder the wires to the circuit board.
Sonuç
Kyle Kramer
255 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 165
