Ana içeriğe geç
Motorola MC5590 Charging Port Replacement
Neye ihtiyacın var
  1. Motorola MC5590 Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Push in the battery release button.
  2. Motorola MC5590 Charging Port Replacement: adım 2, 1 resimden 1.
    • Pull out battery.
  3. Motorola MC5590 Charging Port Replacement, Keyboard: adım 3, 2 resimden 1. Motorola MC5590 Charging Port Replacement, Keyboard: adım 3, 2 resimden 2.
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
  4. Motorola MC5590 Charging Port Replacement: adım 4, 3 resimden 1. Motorola MC5590 Charging Port Replacement: adım 4, 3 resimden 2. Motorola MC5590 Charging Port Replacement: adım 4, 3 resimden 3.
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
  5. Motorola MC5590 Charging Port Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
  6. Motorola MC5590 Charging Port Replacement: adım 6, 2 resimden 1. Motorola MC5590 Charging Port Replacement: adım 6, 2 resimden 2.
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
  7. Motorola MC5590 Charging Port Replacement: adım 7, 1 resimden 1.
    • Remove the keyboard cover.
  8. Motorola MC5590 Charging Port Replacement: adım 8, 3 resimden 1. Motorola MC5590 Charging Port Replacement: adım 8, 3 resimden 2. Motorola MC5590 Charging Port Replacement: adım 8, 3 resimden 3.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  9. Motorola MC5590 Charging Port Replacement: adım 9, 2 resimden 1. Motorola MC5590 Charging Port Replacement: adım 9, 2 resimden 2.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
  10. Motorola MC5590 Charging Port Replacement, Speaker: adım 10, 2 resimden 1. Motorola MC5590 Charging Port Replacement, Speaker: adım 10, 2 resimden 2.
    • Pull the black rubber tabs up gently and remove them.
  11. Motorola MC5590 Charging Port Replacement: adım 11, 2 resimden 1. Motorola MC5590 Charging Port Replacement: adım 11, 2 resimden 2.
    • Using your finger, or spudger, push the motherboard out from the bottom.
  12. Motorola MC5590 Charging Port Replacement: adım 12, 2 resimden 1. Motorola MC5590 Charging Port Replacement: adım 12, 2 resimden 2.
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
  13. Motorola MC5590 Charging Port Replacement: adım 13, 2 resimden 1. Motorola MC5590 Charging Port Replacement: adım 13, 2 resimden 2.
    • Disconnect the speaker from the motherboard.
  14. Motorola MC5590 Charging Port Replacement, LCD Screen: adım 14, 3 resimden 1. Motorola MC5590 Charging Port Replacement, LCD Screen: adım 14, 3 resimden 2. Motorola MC5590 Charging Port Replacement, LCD Screen: adım 14, 3 resimden 3.
    • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
    • Remove the antenna.
    • Remove the flex cable cover.
  15. Motorola MC5590 Charging Port Replacement: adım 15, 2 resimden 1. Motorola MC5590 Charging Port Replacement: adım 15, 2 resimden 2.
    • Remove the five 3mm Phillips #00 screws from the motherboard.
  16. Motorola MC5590 Charging Port Replacement: adım 16, 2 resimden 1. Motorola MC5590 Charging Port Replacement: adım 16, 2 resimden 2.
    • Remove the scanner ribbon cable by pulling straight up and out.
  17. Motorola MC5590 Charging Port Replacement: adım 17, 2 resimden 1. Motorola MC5590 Charging Port Replacement: adım 17, 2 resimden 2.
    • Flip open the motherboard and the LCD screen.
    • Open the LCD connector and remove the cable.
    • Pull the LCD Screen and its metal bracket apart.
  18. Motorola MC5590 Charging Port Replacement, Internal Antenna: adım 18, 2 resimden 1. Motorola MC5590 Charging Port Replacement, Internal Antenna: adım 18, 2 resimden 2.
    • Remove the antenna connector (red box).
    • This is a snap-on connector, which can be removed by applying a gentle pull straight up from the motherboard.
  19. Motorola MC5590 Charging Port Replacement, Charging Port: adım 19, 1 resimden 1.
    • Remove the 2 screws (3 mm long) at the bottom of the motherboard using a PH00-bit screwdriver.
    • Disconnect the charging port from the rest of the device.
Sonuç
Tyler Jean
555 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Cagle Spring 2018 USF Tampa, Team S1-G6, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 303
