Ana içeriğe geç
Motorola MC5590 LCD Screen Replacement
Neye ihtiyacın var
  1. Motorola MC5590 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Push in the battery release button.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola MC5590 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Pull out battery.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola MC5590 LCD Screen Replacement, Keyboard: adım 3, 2 resimden 1. Motorola MC5590 LCD Screen Replacement, Keyboard: adım 3, 2 resimden 2.
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola MC5590 LCD Screen Replacement: adım 4, 3 resimden 1. Motorola MC5590 LCD Screen Replacement: adım 4, 3 resimden 2. Motorola MC5590 LCD Screen Replacement: adım 4, 3 resimden 3.
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola MC5590 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola MC5590 LCD Screen Replacement: adım 6, 2 resimden 1. Motorola MC5590 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola MC5590 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Remove the keyboard cover.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola MC5590 LCD Screen Replacement: adım 8, 3 resimden 1. Motorola MC5590 LCD Screen Replacement: adım 8, 3 resimden 2. Motorola MC5590 LCD Screen Replacement: adım 8, 3 resimden 3.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola MC5590 LCD Screen Replacement: adım 9, 2 resimden 1. Motorola MC5590 LCD Screen Replacement: adım 9, 2 resimden 2.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
    FixBot'a Sor
    Yorum Ekle
  10. Motorola MC5590 LCD Screen Replacement, Speaker: adım 10, 2 resimden 1. Motorola MC5590 LCD Screen Replacement, Speaker: adım 10, 2 resimden 2.
    • Pull the black rubber tabs up gently and remove them.
    FixBot'a Sor
    Yorum Ekle
  11. Motorola MC5590 LCD Screen Replacement: adım 11, 2 resimden 1. Motorola MC5590 LCD Screen Replacement: adım 11, 2 resimden 2.
    • Using your finger, or spudger, push the motherboard out from the bottom.
    FixBot'a Sor
    Yorum Ekle
  12. Motorola MC5590 LCD Screen Replacement: adım 12, 2 resimden 1. Motorola MC5590 LCD Screen Replacement: adım 12, 2 resimden 2.
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
    FixBot'a Sor
    Yorum Ekle
  13. Motorola MC5590 LCD Screen Replacement: adım 13, 2 resimden 1. Motorola MC5590 LCD Screen Replacement: adım 13, 2 resimden 2.
    • Disconnect the speaker from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  14. Motorola MC5590 LCD Screen Replacement, LCD Screen: adım 14, 3 resimden 1. Motorola MC5590 LCD Screen Replacement, LCD Screen: adım 14, 3 resimden 2. Motorola MC5590 LCD Screen Replacement, LCD Screen: adım 14, 3 resimden 3.
    • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
    • Remove the antenna.
    • Remove the flex cable cover.
    FixBot'a Sor
    Yorum Ekle
  15. Motorola MC5590 LCD Screen Replacement: adım 15, 2 resimden 1. Motorola MC5590 LCD Screen Replacement: adım 15, 2 resimden 2.
    • Remove the five 3mm Phillips #00 screws from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  16. Motorola MC5590 LCD Screen Replacement: adım 16, 2 resimden 1. Motorola MC5590 LCD Screen Replacement: adım 16, 2 resimden 2.
    • Remove the scanner ribbon cable by pulling straight up and out.
    FixBot'a Sor
    Yorum Ekle
  17. Motorola MC5590 LCD Screen Replacement: adım 17, 2 resimden 1. Motorola MC5590 LCD Screen Replacement: adım 17, 2 resimden 2.
    • Flip open the motherboard and the LCD screen.
    • Open the LCD connector and remove the cable.
    • Pull the LCD Screen and its metal bracket apart.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Tyler Jean
555 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Cagle Spring 2018 USF Tampa, Team S1-G6, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G6
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 1,051
