Ana içeriğe geç
Motorola MOTO W755 Cell Phone Functional Keypad Replacement
Neye ihtiyacın var
  1. Motorola MOTO W755 Cell Phone Functional Keypad Replacement, Main Logic Board: adım 1, 1 resimden 1.
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  2. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: adım 2, 2 resimden 1. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: adım 2, 2 resimden 2.
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  3. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: adım 3, 3 resimden 1. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: adım 3, 3 resimden 2. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: adım 3, 3 resimden 3.
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  4. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: adım 4, 1 resimden 1.
    • Remove the plastic covering completely from the body of the phone.
  5. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: adım 5, 2 resimden 1. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
  6. Motorola MOTO W755 Cell Phone Functional Keypad Replacement, Functional Keypad: adım 6, 1 resimden 1.
    • Lift the plastic cover of the keypad from the top of the main logic board and peel it off.
Sonuç
Roberta Glenn
43 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-3, Regan SU 2012 Cal Poly, Team 1-3, Regan SU 2012 üyesi
CPSU-REGAN-SU12S1G3
2 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,965
