Ana içeriğe geç
Motorola MOTO W755 Cell Phone Main Logic Board Replacement
Neye ihtiyacın var
  1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: adım 1, 2 resimden 1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: adım 1, 2 resimden 2.
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: adım 2, 2 resimden 1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: adım 2, 2 resimden 2.
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Main Logic Board: adım 3, 1 resimden 1.
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  4. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: adım 4, 2 resimden 1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: adım 4, 2 resimden 2.
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  5. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: adım 5, 3 resimden 1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: adım 5, 3 resimden 2. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: adım 5, 3 resimden 3.
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  6. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: adım 6, 1 resimden 1.
    • Remove the plastic covering completely from the body of the phone.
  7. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: adım 7, 2 resimden 1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: adım 7, 2 resimden 2.
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
Sonuç
C Miller
56 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-3, Regan SU 2012 Cal Poly, Team 1-3, Regan SU 2012 üyesi
CPSU-REGAN-SU12S1G3
2 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,501
