Ana içeriğe geç
Motorola MOTO W755 Cell Phone Speaker Replacement
Neye ihtiyacın var
  1. Motorola MOTO W755 Cell Phone Speaker Replacement, Top Panel: adım 1, 3 resimden 1. Motorola MOTO W755 Cell Phone Speaker Replacement, Top Panel: adım 1, 3 resimden 2. Motorola MOTO W755 Cell Phone Speaker Replacement, Top Panel: adım 1, 3 resimden 3.
    • Use the plastic opening tool to pull peel back screen cover.
    • Gently peel back the screen cover from the speaker slit.
    • Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
  2. Motorola MOTO W755 Cell Phone Speaker Replacement: adım 2, 3 resimden 1. Motorola MOTO W755 Cell Phone Speaker Replacement: adım 2, 3 resimden 2. Motorola MOTO W755 Cell Phone Speaker Replacement: adım 2, 3 resimden 3.
    • Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
    • Move the opening tool around the phone counter clockwise.
    • Pop the plastic cover off by twisting the plastic covering tool.
  3. Motorola MOTO W755 Cell Phone Speaker Replacement: adım 3, 2 resimden 1. Motorola MOTO W755 Cell Phone Speaker Replacement: adım 3, 2 resimden 2.
    • Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
    • Move the plastic opening tool around the phone until part of the casting is popped off.
    • You will need to pop in the four plastic fasteners individually from the metal casing to remove it
    • Be careful not to rip the cable ribbons that are attached to the logic board and casing
  4. Motorola MOTO W755 Cell Phone Speaker Replacement: adım 4, 1 resimden 1.
    • Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
  5. Motorola MOTO W755 Cell Phone Speaker Replacement: adım 5, 1 resimden 1.
    • You now have the top panel completely detached.
  6. Motorola MOTO W755 Cell Phone Speaker Replacement, Speaker: adım 6, 2 resimden 1. Motorola MOTO W755 Cell Phone Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Flip the top portion of the phone so that the back is facing you.
    • Using the flat end of the plastic opening tool, pry the speaker off the back of the phone.
Sonuç
Roberta Glenn
43 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-3, Regan SU 2012 Cal Poly, Team 1-3, Regan SU 2012 üyesi
CPSU-REGAN-SU12S1G3
2 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,584
