Ana içeriğe geç
Motorola Moto 360 2nd Gen Motherboard Replacement
Neye ihtiyacın var
  1. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the watch band: adım 1, 3 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the watch band: adım 1, 3 resimden 2. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the watch band: adım 1, 3 resimden 3.
    • Use your finger or the tip of a spudger to compress the pin securing the watch band.
    • With the pin compressed, remove the watch band.
  2. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the trim ring: adım 2, 3 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the trim ring: adım 2, 3 resimden 2. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the trim ring: adım 2, 3 resimden 3.
    • Insert an opening tool to into the small notch next to the microphone hole.
    • Slide the opening tool around the perimeter of the trim ring while prying up slightly to slice through the adhesive securing the ring to the watch.
    • If the trim ring does not readily separate from the watch, heat it with an iOpener or hair dryer to soften the adhesive.
    • Remove the trim ring.
  3. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the button trim: adım 3, 3 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the button trim: adım 3, 3 resimden 2. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the button trim: adım 3, 3 resimden 3.
    • Use an opening tool to slowly pry the button trim ring straight up.
    • If you bend or rotate the trim ring while removing it, you may damage the small pins that secure it.
  4. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the button: adım 4, 2 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the button: adım 4, 2 resimden 2.
    • Use a small pin spanner to unscrew the button.
    • If you don't have access to the proper spanner, you can use a pair of tweezers, a very small screwdriver, or a paperclip to unscrew the button assembly. Insert your chosen tool into one of the grooves around the button and push sideways.
    • There is blue thread locker on these threads, so light heat on the button may help to soften the thread locker.
    • Remove the button.
    • There is a small red o-ring that may fall off the button threads when the button is removed. Make sure not to lose the o-ring.
  5. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the inner assembly: adım 5, 2 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the inner assembly: adım 5, 2 resimden 2.
    • While holding the outer case steady, twist the inner watch assembly clockwise until it stops.
  6. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 6, 3 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 6, 3 resimden 2. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 6, 3 resimden 3.
    • Hold the outer watch case steady and push against the bottom of the inner assembly to remove the inner assembly from the frame.
    • It should not take much force to push the inner assembly out of the watch frame. If it seems stuck, make sure that you've rotated the inner assembly far enough to release it from the frame.
  7. Motorola Moto 360 2nd Gen Motherboard Replacement, Open the inner assembly: adım 7, 3 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement, Open the inner assembly: adım 7, 3 resimden 2. Motorola Moto 360 2nd Gen Motherboard Replacement, Open the inner assembly: adım 7, 3 resimden 3.
    • Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly.
    • Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first.
  8. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 8, 1 resimden 1.
    • Use tweezers to remove the small rubber strip between the battery and the display ZIF connector.
  9. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 9, 2 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 9, 2 resimden 2.
    • Use a spudger to lift the locking flap on the display ZIF connector.
  10. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 10, 2 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 10, 2 resimden 2.
    • Lift the display cable straight out of its connector on the motherboard.
  11. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the battery: adım 11, 2 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement, Remove the battery: adım 11, 2 resimden 2.
    • Use the flat end of a spudger to gently pry the battery out of the case.
    • The adhesive can be stubborn. If the battery does not come out initially, apply heat to soften the adhesive.
    • If the shield over the motherboard comes off with the battery, use an opening pick to separate the battery and the shield, then snap the shield back onto the motherboard.
    • Do not pull the battery all the way out after you separate it from the shield. There is a fragile battery cable that must be disconnected before the battery is completely removed.
  12. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 12, 1 resimden 1.
    • Use tweezers to lift out the grey plastic cover over the battery connector.
  13. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 13, 2 resimden 1. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 13, 2 resimden 2.
    • Use the point of a spudger to pry up the battery connector and disconnect the battery.
  14. Motorola Moto 360 2nd Gen Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the battery.
  15. Motorola Moto 360 2nd Gen Motherboard Replacement, Motherboard: adım 15, 1 resimden 1.
    • Detach the copper ribbon connecting the motherboard and the display.
    • Use the spudger to separate the motherboard casing from the rear housing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mohammad Abuoliem
125 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G1, Remmell Fall 2017 USF Tampa, Team S6-G1, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S6G1
4 Üyeler
19 adet Kılavuz yazıldı
Bir Yorum
Вопрос у меня возник. я на своих moto 360 2gen 42mm дисплей сломал.и думаю щас если весь корпус от 46mm gen взять, получится ли мою плату туда присобачить ? батарейка подходит от 46 а вот все остальное ? кто что знает
Ричи Грез - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 2,182
