Giriş
If your Motorola Moto 360 3rd Gen smartwatch power button is not responding, you can use this guide to replace it. Before using this guide, inspect the power button, make sure that there is no dust build up. Dust build up can cause the power button to jam. Make sure to power off your smartwatch completely and disconnect from any external power source before attempting this repair.
Neye ihtiyacın var
Use a T4 Torx screwdriver to remove the four 4.2 mm screws securing the lower case.
Gently pry the case open with a halberd spudger if the case will not release after removing the bolts.
Disconnect the right (small, black head) and bottom right ribbons (wide, orange head).
