Ana içeriğe geç
Motorola Moto 360 Battery Replacement
Neye ihtiyacın var
    1. Motorola Moto 360 Battery Replacement, Rear Cover: adım 1, 1 resimden 1.
      • Set the watch face down on a flat surface.
      • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
    2. FixBot'a Sor
      Yorum Ekle
    3. Motorola Moto 360 Battery Replacement: adım 3, 2 resimden 1. Motorola Moto 360 Battery Replacement: adım 3, 2 resimden 2.
      • Gently slide the blue opening pick between the rear cover and the metal casing.
      • The rear cover is extremely fragile. Be very delicate when using the opening pick.
      • Work your way entirely around the rear cover.
      • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Moto 360 Battery Replacement: adım 4, 1 resimden 1.
      • Once the adhesive has been successfully loosened, gently pull the rear cover off.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Moto 360 Battery Replacement, O-Ring: adım 5, 2 resimden 1. Motorola Moto 360 Battery Replacement, O-Ring: adım 5, 2 resimden 2.
      • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Moto 360 Battery Replacement: adım 6, 1 resimden 1.
      • Pinch the green rubber O-Ring and slide it off of the watch.
      • The O-Ring is delicate and is easily severed. Use care around sharp objects.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Moto 360 Battery Replacement, Battery: adım 7, 2 resimden 1. Motorola Moto 360 Battery Replacement, Battery: adım 7, 2 resimden 2.
      • Detach the copper ribbon connecting the motherboard and the display.
      • For reassembly, attach copper ribbon where it is marked.
      • The copper ribbon is fragile and easily disconnects. Remember where it goes so as to reconnect it properly.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Moto 360 Battery Replacement: adım 8, 3 resimden 1. Motorola Moto 360 Battery Replacement: adım 8, 3 resimden 2. Motorola Moto 360 Battery Replacement: adım 8, 3 resimden 3.
      • Use the spudger to separate the battery casing from the rear housing.
      • For leverage, place the spudger in either groove in the rear housing.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Moto 360 Battery Replacement: adım 9, 1 resimden 1.
      • Lift the black plastic pull-tab and pull back on the battery until it's removed from the battery casing. The battery is very firmly secured, so you may have to use a great deal of force.
      • There are two strips of adhesive securing the battery. You may have to use the spudger to loosen the adhesive. Use care not to damage electronics.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Moto 360 Battery Replacement: adım 10, 1 resimden 1.
      • Once the battery is separate from the back of the battery casing, disconnect the red and black wire by prying or pulling it straight up from the board (perpendicular to the board surface).
      FixBot'a Sor
      Yorum Ekle
Sonuç
74 farklı kişi bu kılavuzu tamamladı.
Keslyn Huntington
1.676 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-32, Amido Winter 2015 Cal Poly, Team 17-32, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G32
4 Üyeler
18 adet Kılavuz yazıldı
41Kılavuz Yorumları
Thanks for the guide. However I found several steps at least misleading, or not directly applicable to my Moto 360. I'm not sure if this is because the Moto 360 internal construction has varied over different production iterations.
The key difference is this guide implies that the inner body can simply be slid up and out of the metal shell with slow and careful prying. Actually, there are 4 curved plastic parts (call them locking pins) that fit corresponding slots in the metal shell and the plastic inner body at each side of the top and bottom clasp attachment points. Once inserted during manufacture, there is no way the body will ever slide up and out of the shell. I had to apply significant pressure to bend the shell out and pry the body out past the locking slots. However, it's possible that the locking pins could have been removed with tweezers permitting a less energetic disassembly of the watch.
Mario Becroft - Yanıt Paylaş
Actually, there is a way to remove them. They are flat and tiny, near the watchbands' holes. To remove them, insert something (like a needle, or a toothpick) into the 4 carved out parts and their heads will pop out. Use a screwdriver or nail to gently peel it out. After that, hold the top and bottom (where the watchbands are), and pull the inner body up.
Tran Hoang Nhat - Yanıt Paylaş
I made a video that includes removal of the retaining clips, a critical step missing from all the iFixIt Guides: https://youtu.be/r1as_h5jnBM
davedogcaddy - Yanıt Paylaş
To answer Mike's question, the outside dimensions of the rectangular battery are 30mm x 28mm x ~2.6mm. However, that's not the full story, as the part of the battery module containing the electronics and where the wires attach is thinner than the rest, providing a space about 3mm wide along the narrow edge of the battery that sits above other components on the board.
My asseessment is that there may be space for a slightly larger battery if it was not rectangular, but this would require careful design and provide only marginal benefit.
could an ipod nano battery fit inside?
freestyle695 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 101
Her zaman: 119,505
