Ana içeriğe geç
Motorola Moto 360 LCD Display Replacement
Neye ihtiyacın var
    1. Motorola Moto 360 LCD Display Replacement, Rear Cover: adım 1, 1 resimden 1.
      • Set the watch face down on a flat surface.
      • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
    2. FixBot'a Sor
      Yorum Ekle
    3. Motorola Moto 360 LCD Display Replacement: adım 3, 2 resimden 1. Motorola Moto 360 LCD Display Replacement: adım 3, 2 resimden 2.
      • Gently slide the blue opening pick between the rear cover and the metal casing.
      • The rear cover is extremely fragile. Be very delicate when using the opening pick.
      • Work your way entirely around the rear cover.
      • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Moto 360 LCD Display Replacement: adım 4, 1 resimden 1.
      • Once the adhesive has been successfully loosened, gently pull the rear cover off.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Moto 360 LCD Display Replacement, O-Ring: adım 5, 2 resimden 1. Motorola Moto 360 LCD Display Replacement, O-Ring: adım 5, 2 resimden 2.
      • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Moto 360 LCD Display Replacement: adım 6, 1 resimden 1.
      • Pinch the green rubber O-Ring and slide it off of the watch.
      • The O-Ring is delicate and is easily severed. Use care around sharp objects.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Moto 360 LCD Display Replacement, LCD Display: adım 7, 1 resimden 1.
      • Set the Moto 360 face up on a flat surface.
      • Place the iOpener on the face of the device screen.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Moto 360 LCD Display Replacement: adım 8, 2 resimden 1. Motorola Moto 360 LCD Display Replacement: adım 8, 2 resimden 2.
      • Gently slide the opening pick between the screen and the metal casing.
      • Work your way around the face of the screen, loosening the adhesive.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Moto 360 LCD Display Replacement: adım 9, 2 resimden 1. Motorola Moto 360 LCD Display Replacement: adım 9, 2 resimden 2.
      • Detach the copper ribbon connecting the motherboard to the display.
      • For reassembly, attach copper ribbon where it is marked.
      • The copper ribbon is fragile and easily disconnects. Remember where it goes so as to reconnect it properly.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Moto 360 LCD Display Replacement: adım 10, 1 resimden 1.
      • Slide the display out of the metal casing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Cole Twitchell
1.697 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-32, Amido Winter 2015 Cal Poly, Team 17-32, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G32
4 Üyeler
18 adet Kılavuz yazıldı
7Kılavuz Yorumları
Good morning,
It is possible to replace the display unit for the Moto 360 2nd with 1.56" display?
Thanks in advance and best regards,
Stephan
Stephan Müller - Yanıt Paylaş
Were could i buy a new lcd screen for the moto 360 1st gen??
Sebastian Galvan - Yanıt Paylaş
hey mate you can buy one from aliexpress aliexpress moto 360 screen see link below
https://goo.gl/ZSMTVW
Faddy Oraha - Yanıt Paylaş
Where can I get a LCD display for a Moto 360 2 gen 42mm. Thanks hope you can help
Glenn Patoska - Yanıt Paylaş
Bonjour,
Où est-il possible de trouver des pièces détachées ?
Le fond du boitier.
Merci de votre réponse.
DOGUE - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 43
Her zaman: 22,658
