Ana içeriğe geç
Motorola Moto 360 O-Ring Replacement
Görüntüleme: 3,9 B
İstatistikleri görüntüle:
Son 24 Saat:
2
Son 7 Gün:
21
Son 30 Gün:
89
Her zaman:
3.878
Yorumlar: 35
32 comments on steps, 3 guide comments.
Go to guide comments
Tamamlandı: 2
2 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 0
Hiç kimse bu kılavuzu favorilere eklemedi (ve abone olmadı). İlk mi olacaksın?
Gerekli Süre: 5 dakika
Zorluk: Orta
The O-Ring is fragile. Take care not to let it break when dealing with it.
Neye ihtiyacın var
Aletler
    1. Motorola Moto 360 O-Ring Replacement, Rear Cover: adım 1, 1 resimden 1.
      • Set the watch face down on a flat surface.
      • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
      • Follow the instructions here to remove the back cover without force by using some needles in the right places:
      • Motorola Moto 360 bağlayıcı değişimi
      • Then continue with step 5. Or don't use needles and just continue with the next steps.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Moto 360 O-Ring Replacement: adım 3, 2 resimden 1. Motorola Moto 360 O-Ring Replacement: adım 3, 2 resimden 2.
      • Gently slide the blue opening pick between the rear cover and the metal casing.
      • The rear cover is extremely fragile. Be very delicate when using the opening pick.
      • Work your way entirely around the rear cover.
      • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Moto 360 O-Ring Replacement: adım 4, 1 resimden 1.
      • Once the adhesive has been successfully loosened, gently pull the rear cover off.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Moto 360 O-Ring Replacement, O-Ring: adım 5, 2 resimden 1. Motorola Moto 360 O-Ring Replacement, O-Ring: adım 5, 2 resimden 2.
      • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Moto 360 O-Ring Replacement: adım 6, 1 resimden 1.
      • Pinch the green rubber O-Ring and slide it off of the watch.
      • The O-Ring is delicate and is easily severed. Use care around sharp objects.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Yazar
ile
Jake Steinorth
149 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-32, Amido Winter 2015 Cal Poly, Team 17-32, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G32
4 Üyeler
60 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where can you get your hands on a replacement o'ring?!
James S - Yanıt Paylaş
I broke my o-ring. Any ideas where I could get a raplacement?
Simon Hölz - Yanıt Paylaş
i think you should not take the o ring. i was replaceing the battery without take the O ring
cahyanto emanuel nur - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 89
Her zaman: 3,878
