Ana içeriğe geç
Motorola Moto 360 Rear Cover Replacement
Neye ihtiyacın var
    1. Motorola Moto 360 Rear Cover Replacement, Rear Cover: adım 1, 1 resimden 1.
      • Set the watch face down on a flat surface.
      • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
    2. FixBot'a Sor
      Yorum Ekle
    3. Motorola Moto 360 Rear Cover Replacement: adım 3, 2 resimden 1. Motorola Moto 360 Rear Cover Replacement: adım 3, 2 resimden 2.
      • Gently slide the blue opening pick between the rear cover and the metal casing.
      • The rear cover is extremely fragile. Be very delicate when using the opening pick.
      • Work your way entirely around the rear cover.
      • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Moto 360 Rear Cover Replacement: adım 4, 1 resimden 1.
      • Once the adhesive has been successfully loosened, gently pull the rear cover off.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Cole Twitchell
1.697 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-32, Amido Winter 2015 Cal Poly, Team 17-32, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G32
4 Üyeler
39 adet Kılavuz yazıldı
1Rehber Yorum
How does this *rear cover replacement* count as "no parts required"?
Kyle Mitchell - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 44
Her zaman: 13,588
