Ana içeriğe geç
Motorola Moto 360 Rear Cover Replacement
Görüntüleme: 14 B
İstatistikleri görüntüle:
Son 24 Saat:
3
Son 7 Gün:
23
Son 30 Gün:
119
Her zaman:
13.891
Yorumlar: 23
22 comments on steps, 1 guide comment.
Go to guide comments
Tamamlandı: 9
9 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 3
3 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: 10 dakika
Zorluk: Kolay
This panel should be removed to get to all of the watch's insides. It is extremely fragile, so use caution when removing it.
Neye ihtiyacın var
Aletler
    1. Motorola Moto 360 Rear Cover Replacement, Rear Cover: adım 1, 1 resimden 1.
      • Set the watch face down on a flat surface.
      • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
      FixBot'a Sor
      Yorum Ekle
      • Follow the instructions here to remove the back cover without force by using some needles in the right places:
      • Motorola Moto 360 bağlayıcı değişimi
      • Then continue with step 5. Or don't use needles and just continue with the next steps.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Moto 360 Rear Cover Replacement: adım 3, 2 resimden 1. Motorola Moto 360 Rear Cover Replacement: adım 3, 2 resimden 2.
      • Gently slide the blue opening pick between the rear cover and the metal casing.
      • The rear cover is extremely fragile. Be very delicate when using the opening pick.
      • Work your way entirely around the rear cover.
      • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Moto 360 Rear Cover Replacement: adım 4, 1 resimden 1.
      • Once the adhesive has been successfully loosened, gently pull the rear cover off.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Yazar
ile
Cole Twitchell
1.697 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-32, Amido Winter 2015 Cal Poly, Team 17-32, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G32
4 Üyeler
60 adet Kılavuz yazıldı
1Rehber Yorum
How does this *rear cover replacement* count as "no parts required"?
Kyle Mitchell - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 119
Her zaman: 13,891
