Ana içeriğe geç
Motorola Moto E 2nd Generation Earpiece Speaker Replacement
Neye ihtiyacın var
  1. Motorola Moto E 2nd Generation Earpiece Speaker Replacement, Display Assembly: adım 1, 1 resimden 1.
    • Turn off the device before beginning your repair.
    • Using a heat gun, carefully apply heat around the edges of the display to soften the glue. Heat should be applied to the point where the phone isn't too hot to touch, but close enough.
  2. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: adım 2, 3 resimden 1. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: adım 2, 3 resimden 2. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: adım 2, 3 resimden 3.
    • Using the small plastic opening tool, pry and slide all the way around the phone while carefully lifting up on the display.
    • The screen is secured by two-sided tape located on the edge.
  3. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: adım 3, 3 resimden 1. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: adım 3, 3 resimden 2. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: adım 3, 3 resimden 3.
    • Once display is fully unglued from the frame, carefully lift it up and locate the display connector.
    • Using the same small plastic tool, carefully remove the yellow tape off the connector.
    • Now carefully undo the black connector lock by lifting it up in the direction of the red arrow.
    • Do not pry on the gray part of the connector.
    • Lastly slide the display cable off the connector. It should easily slide off, if not make sure the black lock is fully unlatched.
  4. Motorola Moto E 2nd Generation Earpiece Speaker Replacement, Earpiece Speaker: adım 4, 3 resimden 1. Motorola Moto E 2nd Generation Earpiece Speaker Replacement, Earpiece Speaker: adım 4, 3 resimden 2. Motorola Moto E 2nd Generation Earpiece Speaker Replacement, Earpiece Speaker: adım 4, 3 resimden 3.
    • Now that the display is out, remove the aluminum shield off the motherboard.
    • Unscrew the single 4mm screw located on the top using a T4 Torx bit.
    • After screw is out, gently remove the aluminum shield off the motherboard.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  5. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: adım 5, 2 resimden 1. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: adım 5, 2 resimden 2.
    • Using the metal spudger tool, very carefully remove the speaker by first gently prying up on the right side and then the bottom.
    • The ear piece is held by double sided tape and clips to the motherboard so be very careful.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Andre Romualdo
3.765 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-3, Eyestone Spring 2016 USF Tampa, Team 12-3, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S12G3
3 Üyeler
14 adet Kılavuz yazıldı
3 Yorum
Olá André. Gostaria de saber se aquela peça a direita do earpiece speaker é outro falante.
Questiono pq o meu Moto E2 apresenta um som meio chiado nas ligações, porém no viva voz ou reproduzindo mídia o som é limpo, normal.
Obrigado.
Caio Andrade - Yanıt
I almost bought another phone but I read it was common for these phones to have ear piece issues like mine does.
Thank You so much for the information it was perfect, I just ordered the ear piece.
sarjpr - Yanıt
Ciao Andre e grazie davvero!
enricolag - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 12
Her zaman: 10,546
