Ana içeriğe geç
Motorola Moto E Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Motorola Moto E Rear Facing Camera Replacement, Motherboard: adım 1, 1 resimden 1.
    • Turn off the device before beginning.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
  2. Motorola Moto E Rear Facing Camera Replacement: adım 2, 1 resimden 1.
    • Unscrew the 14- 4mm screws using a T4 Torx driver head.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  3. Motorola Moto E Rear Facing Camera Replacement: adım 3, 1 resimden 1.
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
  4. Motorola Moto E Rear Facing Camera Replacement: adım 4, 1 resimden 1.
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
  5. Motorola Moto E Rear Facing Camera Replacement: adım 5, 1 resimden 1.
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
  6. Motorola Moto E Rear Facing Camera Replacement: adım 6, 1 resimden 1.
    • Unscrew the 3- 1mm screws using the T4 torx driver head.
  7. Motorola Moto E Rear Facing Camera Replacement: adım 7, 1 resimden 1.
    • Lift up on the white plastic mount.
    • Pull the orange ribbon cable out gently.
  8. Motorola Moto E Rear Facing Camera Replacement: adım 8, 2 resimden 1. Motorola Moto E Rear Facing Camera Replacement: adım 8, 2 resimden 2.
    • Gently pull the black ribbon cable out.
  9. Motorola Moto E Rear Facing Camera Replacement: adım 9, 1 resimden 1.
    • Using the metal spudger, pry the motherboard away from the screen assembly.
  10. Motorola Moto E Rear Facing Camera Replacement, Rear Facing Camera: adım 10, 1 resimden 1.
    • Use the plastic opening tool to pry the metal housing off.
  11. Motorola Moto E Rear Facing Camera Replacement: adım 11, 1 resimden 1.
    • Remove the rubber cover on the camera by gently lifting it up.
  12. Motorola Moto E Rear Facing Camera Replacement: adım 12, 1 resimden 1.
    • Use the same plastic opening tool to pry the camera assembly off.
    • Use the plastic opening tool on all four sides of the camera several times until it starts to come loose.
  13. Motorola Moto E Rear Facing Camera Replacement: adım 13, 1 resimden 1.
    • Pull the camera assembly out.
    • Place the new camera assembly into the connector and press gently.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alex Craig
2.596 İtibar
5 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015 üyesi
UCCS-PANKO-S15S5G7
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 3,172
