Ana içeriğe geç
Motorola Moto E4 Motherboard Cover Replacement
Neye ihtiyacın var
  1. Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: adım 1, 2 resimden 1. Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: adım 1, 2 resimden 2.
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: adım 2, 2 resimden 1. Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: adım 2, 2 resimden 2.
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Motherboard Cover Replacement: adım 3, 2 resimden 1. Motorola Moto E4 Motherboard Cover Replacement: adım 3, 2 resimden 2.
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nate Tjepkema
1.254 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G4, White Winter 2019 Cal Poly, Team S2-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S2G4
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 643
